Changing TCM and PCM together
Old 26 Dec 2010, 11:35 pm
Default Changing TCM and PCM together
I mistakingly posted this under Events...I have a 2002 PT Cruiser with an engine code of P0605 which is the TCM (It's an automatic that won't shift out of first gear despite the speed). If I find a used PCM and TCM from the same vehicle, will they need to be flashed? I'm assuming the TCM is flashed to the PCM, but if they came from the same vehicle, would not they have already been flashed to each other? Are there any other components that would have to be flashed? Thanks for your help!
Changing PCM and TCM together Benodom Tech & Performance Forum 0 26 Dec 2010 11:22 pm
Changing wires Scrathy Tech & Performance Forum 4 25 Aug 2009 08:17 pm
Changing the battery PTJake General PT Cruiser Discussions 14 20 Dec 2007 11:35 pm
changing oil tm05cruiser Tech & Performance Forum 1 31 Oct 2007 12:10 pm
Changing the PCV Valve emery Tech & Performance Forum 2 07 Dec 2001 05:05 am
