2005 PT timing belt change
Old 28 Dec 2010, 12:55 am
Default 2005 PT timing belt change
Sorry, yet another post regarding timing belt changes. I have finally figured out that if I jack the engine high enough I can get the engine mount out of the engine compartment. The question I have is are there any differences between the '03 and the '05 as far as setting up the tensioner goes, or anything else for that matter? The Chiltons manual I purchased that is supposed to be for an 01-09 talks about the 01-03 models, but is silent on anything newer. I hate Chiltons manuals, but I figured anything would be better than nothing...not. Unbelieveable how they managed to stuff 10 pounds of poo into a 5 pound container...
Old 28 Dec 2010, 08:12 pm
Default Re: 2005 PT timing belt change
So the answer is yes, the 2005 is the same as a 2003 - got it back together today. Also, I used a Motion Pro clutch tool for motorcycles to hold the camshaft gears, it worked great. Here is an example of the tool: Amazon.com: Motion Pro Clutch Holding Tool - --/--: Automotive
Old 28 Dec 2010, 09:02 pm
Hey, since you did it yourself (good job ) maybe you can help this guy:
Timing Belt Tensioner
Old 30 Dec 2010, 10:22 am
Wow, sucks to be him. I disconnected the MAP sensor (as well as many others) to move the intake manifold out of the way to get to the heater hoses to change them. I didn't get the connector seated good on the first try; went to go for a test drive and has a check engine light and a car that idled fine but would try to die under any sort of load. Anyway, 30 seconds with a scan tool, finished plugging the MAP sensor in, and off I went. Guess its better to be lucky than good...
when to change Timing belt ? Ctown General PT Cruiser Discussions 13 18 Aug 2014 05:40 pm
After timing belt change veracruise Tech & Performance Forum 5 03 Dec 2010 07:17 pm
Timing belt change - is this possible? nx13688 Tech & Performance Forum 1 14 Oct 2010 06:50 pm
Timing Belt Change? tgibeau Tech & Performance Forum 10 07 Jun 2010 10:21 pm
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
