Crankshaft oil seal replacement help
Old 01 Jan 2011, 09:42 pm
Default Crankshaft oil seal replacement help
I am replacing my timing belt and noticed the crankshaft oil seal is leaking. I would like to replace the seal but I need to know what size bolt I need to thread into the crank. I have a crank puller kit that i used to remove the balancer pulley but the bolts are to large to fit the the holes so i am looking for the correct size bolt to remove the sprocket. Thanks.
Old 02 Jan 2011, 11:56 am
tryingbe's Avatar
Default Re: Crankshaft oil seal replacement help
It's M6 something for the three bolts holes at the timing belt sprocket. The center bolt is M12 x 1.75. I had to run a tap to my crank due to damage thread by the previous person that worked on it.
My local Aces Hardware had the M6 metric bolts and a M12 100mm all stud. I bought two all studs, one use to remove the sprocket, because you will destroy its top using a puller on it. The other for replacing the center bolt as it was damage and I don't like the bolt. I replaced the center bolt with an all stud, washer, a nut, and used thread lock.
To install the timing belt sprocket, you're going need to a special tool or use a long M12 x 1.75 x 300mm stud, a nut, a washer, a axle nut socket, and lube.
You can buy the stud here. McMaster-Carr
Good luck.
85 GLH
Watch out for anchor engine mounts!!
Old 02 Jan 2011, 02:05 pm
Any tips for getting the seal out and installing a new one? I am going to work on this in the morning.
Old 02 Jan 2011, 03:35 pm
tryingbe's Avatar
If it is already leaking, it should come out very easy.
Pry carefully, and don't damage any metal surface.
85 GLH
Where is the crankshaft sensor? barry8108 Tech & Performance Forum 2 08 Dec 2010 06:24 pm
Crankshaft BACdaG1 Feedback and Support 0 09 Nov 2010 09:36 pm
HELP! Crankshaft pos sensor won't come out! reluctantlycrouched Tech & Performance Forum 0 09 Jul 2010 08:33 pm
Crankshaft damper won't come off!! able2able Tech & Performance Forum 7 03 Jun 2010 09:48 pm
camshaft oil seal replacement? MrDove Tech & Performance Forum 1 20 Jan 2009 02:20 pm
