broken exhaust stud at manifold
Old 02 Jan 2011, 02:17 pm
Default broken exhaust stud at manifold
While redoing my timing belt I snapped the bottom exhaust stud where the pipe bolts to the manifold. Anyone have any advise for removing the broken stud and replacing it? I was thinking of heating the manifold with a torch and pounding the broken one out.
I am going to check with the dealer in the morning and see if i can buy just the stud from them.
Anyone know where I can get an after market stud and or what size it is? I know the bolt is M8 x 1.25. Thanks.
Old 03 Jan 2011, 01:05 pm
Default Re: broken exhaust stud at manifold
My advice - soak with PBBlaster, get an "EZOut" tool. You drill a small hole in stud, then use reverse thread screw to work the bolt out (that's the EZOut)
You may need heat, but pound it out?
Old 03 Jan 2011, 01:17 pm
To me it looked like a pressed in stud. When they broke on my truck i heated them red and they pounded right out. This is on the part where the exhaust pipe bolts to the manifold not where the manifold bolts to the engine.
Old 03 Jan 2011, 01:37 pm
Ah, so! Then you're probably right.
Go easy pounding - the exhaust manifold is cast iron, don't wanna crack it!
Old 03 Jan 2011, 04:03 pm
I called the dealer, they dont sell the stud. But they said it is M8x1.25x35. I think I am just going to get a bolt that size and tighten it up with a wrench.
I plan on using my air hammer to knock out the stud since I wont have much room to swing a hammer.
Exhaust Manifold Help trieber Tech & Performance Forum 16 26 Dec 2011 11:22 am
wtb good used exhaust manifold anthony_plumlee Classifieds: Want To Buy 3 08 Aug 2011 04:48 am
01 & 02 same exhaust manifold? chuck2112 Tech & Performance Forum 1 29 Jan 2010 02:29 pm
Exhaust manifold don668 General Turbo Discussions 4 22 Jan 2005 03:35 pm
Broken exhaust stud royarchr General Turbo Discussions 9 02 Nov 2004 06:55 pm
