I have read some of the other P0340 threads, they all seem to be DIY, which I can't do. I would like some advice for what to ask the mechanic when I take my car back to the dealer next week. I still have 2+ years of extended warranty left ;-)
I have been having engine light coming on, and engine bolting when I first accelerate. I did the ignition trick and got fault code P0340. Took it to dealer, they claimed they fixed it, but Friday evening after I picked it up, it started all over again. Here is what my invoice says they did: 10CHZ06 Scan Unit and had Fault Code P0340, Camshaft Sensor Circuit Bank. 1, Performed TSB to Reprogram PCM and Retest O.K. 6037 CP 0.80 Whatever TSB is, did not fix my problem. I still get the same P0340 fault code. Does anyone in this forum know what TSB is? Do you think they replaced the Camshaft Sensor? If so, can you advise me what they should try next? I appreciate any help. I love this car (my 2nd PT), and just want it to run good again ![]() Belle Last edited by LaureBelle; 02 Jan 2011 at 09:49 pm. |
It has been my experience in the past that if you take a car in with a warning light on they just put it in the bay and reset the light with no diagnostics at all.They will tell you that they fixed the problem and hope all is good.I took my previous car in with the TPMS light on and they had the car in the bay for less than 10 minutes and said it was fixed.I got about 10 miles from the shop and the light was back on.I took it back and then they actually diagnosed and fixed the problem.Not saying this is the case with your car but I have seen it happen on more than one occasion.
As stated above,you should take it back to them and have them check it again. Last edited by SCBluePT; 02 Jan 2011 at 10:40 pm. |
Greetings from San Antonio, welcome to the site.
So Eve, my 07 Touring Edition, threw those same codes at me. the first time it happened i was able to get her home then i disconnected the battery for something i was doing and when i connected the battery again, the code was gone. So two weeks later it happened again, she gave me the same code. So i disconnected the battery for like 5 mins so i could make it home. the next day i went to the local dealership and bought the part and installed it. but we'll see if it works. she runs fine and no codes. It's actually like a 3 minute install so i would suggest buying the part and having someone put it in for you. You gotta make sure that it's directly from Chrysler, i've been told that our PT's don't like after market electronics. But i forgot that i have a short ram air intake so that's why it only took me three minutes to install it. but what you would have to do is remove the air intake box, which is very simple. and then you'll have access to the camshaft sensor. you unscrew it, and unclip it. The you clip the new one in, bolt it back and then place the air box back on and then that's it.
-Danny Wolfman G http://www.facebook.com/WolfmanG You can see all of her mod's at http://www.facebook.com/media/set/?s...8&l=c6026ea5f4 "Dream as if you'll live forever, Live as if you'll die today" - James Byron Dean.
Belle,
The TSB is a Technical Service Bulletin that tells the mechanic how to best fix a known problem when a customer has problems. It still costs you money unless like you said your under warranty. If the cars still running OK, sometimes the dealer just resets the computer, makes sure you have the latest programming and sends you on your way. I'd keep going back to the dealer since your under warranty and they will/should eventually give you a new camshaft sensor and hopefully check the wiring harness becuase there has been problems with the wiring.
... ...![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 115,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage. Visit My Home Page www.CREWZIN.com NY Times article: http://www.nytimes.com/2008/10/30/au...30vintage.html Last edited by CREWZIN; 03 Jan 2011 at 11:20 am. |
at the beginning of all tsb's it says to perform bisic diagnostic procedures then procede. young techs like to jump right to the tsb and forgo the diagnostic's. tsb are not the best fix but just another tool the tech can use in his diognostic arsanal. after 36 years as a tech i get real tired of comebacks due to lazy techs. sorry i just had to vent a little it is a real sticky point to me.
IF IT AINT BROKE DON'T FIX IT |
I have the same problem in the past. what i've did was that i asked the dealer for the Technical Service Bulletin and gave it to my buddy who's a techie man. Sometimes its hard to trust the dealer's auto repair center. They're not doing their job actually. They'll just diagnose your car and then will say that its fine. But the real thing is not. It is better if you go to a mechanic where you can put your trust. TSB may not be the best repair manual but it is still important and is necessary most especially if your auto is undergoing some repairs.
| Tags |
| 2006 pt cruiser, fault code p0340 |
| P0340 cam sensor code in 2006 cruiser | deighter | Tech & Performance Forum | 13 | 12 Jan 2012 06:41 am |
| Fault Code Retrieval | bob2006 | Tech & Performance Forum | 15 | 18 Jun 2011 07:50 pm |
| Error code P0340 ADVICE??? | mjb457 | Tech & Performance Forum | 10 | 20 Aug 2009 09:24 pm |
| Fault code P0685 | martyd1972 | Tech & Performance Forum | 2 | 16 Jul 2009 01:41 am |
| Fault code | RossiePT | General Turbo Discussions | 8 | 28 Mar 2004 09:52 pm |
