grinding noise 06 pt crusier
Old 05 Jan 2011, 03:40 pm
Default grinding noise 06 pt crusier
i have a pt cruiser thats been making grinding noises coming from the front passanger side. at first it was just when braking but now its starting to happen when doing highway speeds. it started happening after i id a front brake job. after a month of it grinding i checked all the brakes on the car for signs of grinding but it had absolutely no signs of grinding i check the front wheel bearing and they had no vertical play. i just have no clue what is wrong with it.
Old 05 Jan 2011, 04:28 pm
cruserdad1976's Avatar
Default Re: grinding noise 06 pt crusier
if it is from the right side it almost has to be a bearing or the brakes io maybe the caliper is not installed exactally right have you took the brakes off to check them????
Old 13 Feb 2011, 11:11 pm
Did you find a resolution to the grinding?
I'm experiencing the same description on mine.
I checked the brakes and they are still at about 70% and have no sign of grinding or uneven wear.
Old 06 Mar 2012, 05:41 am
Cool Re: grinding noise 06 pt crusier
I have the exact same problem, and my friend has it with his 95 intrepid. He has had it for 9 years same problem never able to figure it out. Brakes are always good and rotors too. It might be a bearing. I am yet on the mission of figuring it out. I'll be back with the answer. Hopefully
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Whining / grinding noise. PtOnAir Tech & Performance Forum 13 09 Dec 2012 04:44 pm
Grinding noise. PtOnAir Tech & Performance Forum 6 10 Jan 2011 09:40 am
Another Grinding Noise... bjagd02 Wheels, Tires, Suspension 3 01 Nov 2010 09:01 am
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
