Air box removal
Like Tree8Likes
Old 06 Jan 2011, 07:24 pm
chintzgirl's Avatar
Default Air box removal
I apologize if this has been done to death but........ tried a search and a goggle and can't find a step by step to remove the air box. I'd like to do the mod this coming weekend.
Thanks for any help
Ps. Are the air boxes interchangeable? If I found one at a wrecking yard (just in case something goes wrong) would it have to come from an 2004 (my baby's year)
Karen and Lil' Nilla
Old 06 Jan 2011, 08:10 pm
Default Re: Air box removal
Any airbox will fit.
After removing the intake hose and removing the top cover and filter. Looking into the lower box you will see two holes, they are pegs that are into rubber bushings on the fender. Pulling straight up it can be removed, do NOT twist but give it a good YANK up!! Good luck and let us know how it went.
Old 06 Jan 2011, 08:43 pm
WolfmanG's Avatar
yup, it's as simple as that. take off the hose, the top of the box and pull up, takes like 3 minutes. Then from there if you ever have a problem with the camshaft position sensor then it's like a 3 minute job to replace it.
-Danny Wolfman G
Old 06 Jan 2011, 08:51 pm
chintzgirl's Avatar
[QUOTE=Then from there if you ever have a problem with the camshaft position sensor then it's like a 3 minute job to replace it.[/QUOTE]
Whoa! what's this all about? I just want to do the airbox mod. I'm I biting off more than I can chew ? Camshaft? is this something I could 'hurt' doing my air box mod ?
Old 06 Jan 2011, 09:24 pm
No. Don't worry. The comment about the camshaft position sensor simply points out that the air box takes up space blocking access to other systems.
As to how extensive the project you are undertaking is, tell us what your air box plans are. You mention getting another box from salvage.
I plan likewise to get a back up box before I begin slicing and dicing my airbox inlet.
Old 06 Jan 2011, 10:25 pm
chintzgirl's Avatar
oh, well that's good. For a moment I was stunned LOL Any road, here's my plan.
How to: Air filter box modification
I bought the K&N drop in ( which by it's self has already improved HP) so I thought I go the whole hog and do the mod as well.
Thanks Hooligan for the removal directions.
Old 07 Jan 2011, 01:02 am
WolfmanG's Avatar
what the hell, i don't get any thanx for scaring the crap outta you? lol jk. but what i meant is exactly what sanatanadharma said. The air box takes up a lot of space. I had to change my cam shaft sensor a while ago so that's why i threw that in there. No worries.
-Danny Wolfman G
Old 07 Jan 2011, 10:06 am
chintzgirl's Avatar
Originally Posted by gkid1983 View Post
what the hell, i don't get any thanx for scaring the crap outta you? lol jk. .
hahaha. How rude of me, yes, thank you for the cardio workout! Must do this more often, saves going to the gym.
Old 07 Jan 2011, 11:07 am
It is not true that all airboxes are the same - turbos are different and '01 - '05 are different from '06 on up.
Old 07 Jan 2011, 12:52 pm
QSD, you are so right that there is a difference in 01-06's, however the removal is the same.
Antenna removal Bevynn Sound and Security Forum 4 23 Apr 2009 07:57 pm
Roll Bar Removal Badger PT Cruiser Convertible Forum 18 22 Jun 2008 11:06 pm
ROTOR REMOVAL paully Tech & Performance Forum 11 14 Feb 2006 02:25 pm
MIRROR REMOVAL SIXIMPS Exterior Accessories Forum 1 10 Oct 2005 12:39 pm
Headlight removal? DBROWN03 Exterior Accessories Forum 4 19 Sep 2005 02:30 pm
