infamus p1128
Old 10 Jan 2011, 05:27 am
urimashe's Avatar
Default infamus p1128
OKAY, Question.... what does this mean? i mean..... what does it means exsactly wrong with it and whats the fix for it? i cant find much info or detailed info on this anyweres.....
2006 Base PT Manual Tranny, K&N drop in filter, Marine Blue paint, Name: Blue Monster, Body style: Path Cruizer... oh yea, seat covers? got em.
Old 10 Jan 2011, 05:55 am
Default Re: infamus p1128
SYMPTOM/CONDITION:
The MIL may illuminate due to Diagnostic Trouble Code (DTC) P1128
This is from the TSB/NHTSA lookup table:
TSB 1800206
NHTSA ITEM NUMBER - 10019249
P1128 - Closed Loop
Fueling Not Achieved - Bank 1. This condition can occur when the engine is started in cold ambient temperatures between 14° F (-10° C) and 32° F (0° C) and allowed to idle until warm.
DIAGNOSIS:
Using a Scan Tool (DRBIIIŽ or StarSCANŽ) with the appropriate Diagnostic Procedures
available in TechCONNECT, verify all engine systems are functioning as designed.
If DTCs are present record them on the repair order and repair as necessary before
proceeding further with this bulletin.
If the vehicle operator describes or experiences the Symptom/Condition, perform the Repair Procedure.
Looks like you need to have it diagnosed with a scanner at a dealer or mechanic with the right tools.
Old 10 Jan 2011, 06:29 am
urimashe's Avatar
dang it.... this realy sucks the code went away after starting it again.... i knew this thing had a cold start problem but this is getting rediculouse....
