Oil Burning
Old 10 Jan 2011, 01:37 pm
Default Oil Burning
Hello
Last weeken I change my oil and I have put about 150 miles on it. I cleaned the pcv valve in mineral spirit because it was a little sticky. I usually only use about a half quart between oil changes,which is not a big deal. But now I have burned about a quart an a half in 150 miles. Could this problem be the PCV valve?
Thank you
Chad
Old 10 Jan 2011, 04:28 pm
Default Re: Oil Burning
Chad.
If you've cleaned it and it rattles when you shake it, the PCV valve should be good and even if it wasn't working, I don't think you'd use that much oil. 1 1/2 quarts in 150 miles is extremely excessive. Your either burning it or loosing it. Take a good look around and under the engine for leaks and see if it's blowing out the exhaust at idle.
Old 11 Jan 2011, 08:50 am
Zero in on the filter and drain plug. Sometimes the old O-ring sticks to the engine, and that guarantees a leak, and the drain plug can get stripped.
Old 11 Jan 2011, 10:30 am
Dino's Avatar
The PCV valve cost nothing and I have seen them cause oil leaks so why not just change it.
Old 11 Jan 2011, 04:59 pm
where is this pcv valve and where can I find a new one?
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
Old 11 Jan 2011, 05:16 pm
Follow the hose from the bottom of the air box over to the valve cover, it should be at that end. Most auto stores will carry them, if the valve ball still rattles it still is good.
VIN burning on stock used pcm sylster Canada PT Forum 17 20 May 2011 12:08 am
Burning 1 Qt. oil every 2K on '06 w/ 37K???? 66CUDA Tech & Performance Forum 11 14 Mar 2010 09:40 am
Two Months of Burning up the Road SantaGuy General PT Cruiser Discussions 1 13 Oct 2009 08:58 pm
stage one burning my sensors ? murman40 Stage Turbo Kits 4 19 Jan 2009 12:59 am
Odor of burning wood wearl50 Tech & Performance Forum 12 14 Mar 2004 04:16 am
