Vacuum leak help
Old 10 Jan 2011, 07:40 pm
Question Vacuum leak help
Hi,
After changing the wires/plugs there seems to be a vacuum leak, a hissing noise. I've checked the obvious connections. I've checked the pcv hose, hose connections behind the manifold, throttle body etc. Any suggestions would greatly appreciated.
Thanks
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 10 Jan 2011, 07:44 pm
Default Re: Vacuum leak help
Since you just changed the plugs and wires I'd check the area around where the upper and lower manifold come together.
Old 10 Jan 2011, 08:12 pm
Whats the best way to check it?
Old 10 Jan 2011, 08:20 pm
Get a can of WD-40 and while the engine is running spray around the two halves of the manifold and listen for any change in idle.
Old 10 Jan 2011, 08:27 pm
If there is a change. I'm assuming it's not been tightened correctly? It makes a puh noise when I turn the car off.
Old 10 Jan 2011, 09:08 pm
Gasket may not be sealing, unless it was twisted upon assembly they are reusable. The torque isn't very much around 12 inch lbs, I think, I usually just snug them down using 1/4" socket ratchet. Good Luck!!! Let us know how you make out.
Sounds like you need to take it apart again, check the 4 rubber gaskets and very careful when putting it back together. You also need to tighten the 5 bolts down to specific torque.
Old 10 Jan 2011, 09:51 pm
I'll let her sit until the weather gets better. I'll repost once I take it apart.
Old 11 Jan 2011, 08:25 am
IF you wait to long the twisted (if it is) gasket may keep the twist and will NOT be able to seal.
Old 11 Jan 2011, 09:41 am
I checked the gaskets this morning and they are not twisted. (seated properly and tightened the intake manifold correctly). Still hissing somewhere.
vacuum line bhunt41 Tech & Performance Forum 0 02 Jan 2011 03:19 pm
Which hose for vacuum gauge codfather204 Tech & Performance Forum 2 19 Aug 2010 09:48 pm
Vacuum hoses PTcruzer02 Tech & Performance Forum 3 22 May 2010 07:23 pm
vacuum t-connector location. anyone have a pic? pppt03turbo Tech & Performance Forum 0 15 Oct 2007 03:49 pm
Vacuum Line Diagram turbokidd Turbo Performance 1 17 Sep 2007 11:55 am
