How much oil to you use between changes??
Old 11 Jan 2011, 10:41 am
Dino's Avatar
Default How much oil to you use between changes??
I hear a lot of people talking about unexplained oil lost between changes. Now I don't use a drop I just checked again and I'm at 3500 miles since my last change and not a drop is missing.
Now I do use synthetic oil and I do use Royal Purple but even when I used a different brand synthetic I had the same results. So is it maybe the Dino oil that gets used up faster or something else?
My car has 67k on it. So lets try to get a count on PT's and see if we can see any common issue on why you lose oil or why you don't.
Old 11 Jan 2011, 10:46 am
Default Re: How much oil to you use between changes??
Coming up to 107,000 miles and changing oil at 5,000 mile intervals for the past couple of years and use less than 1/2 a quart between changes. Have alwys used Mobil 1.
Old 11 Jan 2011, 11:47 am
My oil has only gone low one time, that was when I went 9000 miles between oil changes. I usually change oil every 5k, but let it go through fall. Was about not quite a half quart low. I can attribute most of that to tossing it up the make-up air tube from driving like a total maniac.
Old 11 Jan 2011, 01:58 pm
I go 7,000 miles with full syn, 1/2 quart low typical. Over 190,000 miles on it.
Old 11 Jan 2011, 02:07 pm
yaris's Avatar
78000km 06 N/A, usually it drop by around 250ml to 500ml between changes at every 15000km. I use castrol syntec oil
Old 11 Jan 2011, 02:56 pm
cruserdad1976's Avatar
06 na i change it every month about 4000 it maybe 1/4 quart low i run castrol mix
Old 11 Jan 2011, 07:48 pm
soonercruiser's Avatar
Talking Re: How much oil to you use between changes??
Have had 3 different Cruisers; all used Mobile 1; no oil loss in any!
Frank, aka SOONERCRUISER,
Old 12 Jan 2011, 12:19 am
Dino's Avatar
Great going on a 190k PT
I'm hoping some of the guys that lose oil report in, I'm curious what kind of oil they use and how long they usually go between oil changes.
Old 12 Jan 2011, 08:38 am
I have an 01 limited with 72,000 miles. The amount that I lose is always different. Usually anywhere between 1/2 to 1.5 qt every 4000 miles or so.
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
