How many Motor or Transmission Mounts?
Old 11 Jan 2011, 02:19 pm
Default How many Motor or Transmission Mounts?
I have a 2002 PT Cruiser with Auto Transmission. I replaced the 2 motor mounts on the passenger side and it got rid of some clunking sounds. I previously replaced all the A arm bushings and struts.
I am still getting a clunking sound from the passenger side. Are there any more mounts? Transmission mounts, motor mounts on Driver side etc?
Thank You for you help.
Old 11 Jan 2011, 08:10 pm
mityqwik's Avatar
Thumbs up Re: How many Motor or Transmission Mounts?
i have an 06 with the same thing and have replaced the motor mounts on the passenger side also there is one more motor mount on the pass.side i have not dealt with and dont look foreword to it and am not sure that is whats making the sound,i was told that my pass.side upper strut mount was making the noise and will replace it first.if that does it i will post the results here,maybe chromenut or crewzin and add more here
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 11 Jan 2011, 11:19 pm
Default Re: How many Motor or Transmission Mounts?
I've not done any work on the '02 or '06 motor mounts....yet. This summer I plan on replacing my motor mounts as I've thrashed mine by driving like a maniac.
Let me look in the parts catalog...
Well, this site won't allow me to upload the three pages I pulled from the catalog, it's about 85k (almost tiny).
So here, download it from my site. Maybe that will help you out...
Mity, do you want the same for the '06?
Old 11 Jan 2011, 11:39 pm
mityqwik's Avatar
yes sure would thanks chromenut
Old 12 Jan 2011, 11:59 am
UptownSport's Avatar
The passengers mount is horrible to replace. My suggestion is:
1. Drop the powertrain
2. Use 3M Windshield Urethane.
The Neon mounts ('00 and up) were even worse than the older models, PT shares the common design (the rubber, per se, may be of different firmness).
The urethane will fix a torn mount permanently, if you fill the mount totally it will transmit vibrations to the occupants, some don't mind and some like it!
Old 12 Jan 2011, 12:49 pm
I already replaced the passenger mounts. Actually super easy for me. Took about 30 minutes. The upper and lower, I didn't fill with urethane. I got them cheap enough and easy enough to replace I can change them very 30 to 60k with no problem.
I replaced #3 and #4 on the Diagram which are described as Engine Mount Isolators. They look like the only ones that have rubber in them. All the other are metal mounting locations which shouldn't require to be changed, from what I can tell.
Does anyone else know if there are any other supports or isolaters I am missing?
Old 12 Jan 2011, 02:35 pm
Try # 1 ...
It'd drive a priest to drink.
Old 12 Jan 2011, 02:52 pm
Great info. The Neon SRT-4 motor mounts are stouter and fit the PT. There is also one tranny mount on the driver side.
Old 12 Jan 2011, 03:58 pm
Ahh, a tranny mount. That could be my issue. Do you know its general location on the driver side. Do you know a part number?
The tranny mount looks like the others, so the rubber inside is bound to be bad. I think this is it:
http://www.autopartswarehouse.com/sk...%26+Drivetrain
Old 18 Jan 2012, 11:53 am
jdpersico's Avatar
This is the transmission mount:
2001-2006 Chrysler PT Cruiser Motor and Transmission Mount, 01-06 Chr
You can find it under the battery.
Motor Mounts go-vair Turbo Performance 14 03 Apr 2017 10:50 pm
Motor mounts sdwilson Tech & Performance Forum 8 03 Aug 2010 12:49 pm
Motor Mounts pkpt04 Tech & Performance Forum 14 21 Aug 2009 10:02 pm
PT MOTOR MOUNTS HELP !! BARRYPT General PT Cruiser Discussions 2 18 Jan 2008 12:44 am
motor mounts knowyourturbo Classifieds: For Sale/Trade 1 23 Mar 2006 07:36 pm
