2001 PT- Replacing the 4 Motor Mounts
Old 12 Jan 2011, 12:14 pm
Arrow 2001 PT- Replacing the 4 Motor Mounts
I have the 2001 model PT Cruiser - not turbo. I have 4 Moror mounts that are cracked. What is involved in replacement of the upper mounts? How about the lower mounts?
I know all 4 have a purpose but which 2 are the most important to get fixed now then the other 2? I need your opinions on this issue.
Which mount is the most labor intensive?? If anyone has any pictures of the mounts and how to repair it is greatly welcome!!!!!!!
Old 12 Jan 2011, 12:46 pm
Default Re: 2001 PT- Replacing the 4 Motor Mounts
I only know of the 3 on the passenger side. I is solid on the motor. Typically fine. Then the 2 rubber ones, upper and lower that are always bad at around 60K miles, definitely replace and easy.
Where is the 4th one?
Old 12 Jan 2011, 02:55 pm
There are two motor mounts (torque struts) on the passenger side that need to be changed. There is a solid one on the pass side that rarely, if ever needs to be changed. There is no 4th one on the pass side.
Motor Mounts go-vair Turbo Performance 14 03 Apr 2017 10:50 pm
Replacing Motor Mounts geronimo Tech & Performance Forum 7 21 Mar 2010 01:27 pm
Motor Mounts pkpt04 Tech & Performance Forum 14 21 Aug 2009 10:02 pm
Motor mounts saldagus Tech & Performance Forum 6 15 Apr 2009 09:06 am
motor mounts? 2004PTCruiser Tech & Performance Forum 0 31 May 2008 04:50 pm
