re: Timing Belt Alignment Question
Old 13 Jan 2011, 01:02 pm
Default re: Timing Belt Alignment Question
I'm just about to remove the old T-Belt and wanted to see how the original belt marks line up.
I thought, to check for TDC, you turn the crank so the crankshaft marks line up and this should result in the camshaft marks lining up? Didn't happen.
When aligning the camshaft marks, the crankshaft appears to align with the trailing edge of the crank tooth (not centering on the tooth).
Is that what you normally see? Thanks.
Old 13 Jan 2011, 02:43 pm
Default Re: Timing Belt Alignment Question
Never mind... i found an old post which explained that this is correct.
Sorry.
Another Timing Belt Question...(sorry!) sscanlan Tech & Performance Forum 10 17 Nov 2010 11:04 pm
Another possible timing belt question PTBlue_2002 Tech & Performance Forum 2 16 Jun 2009 06:51 am
Timing Belt Question bmore25 Tech & Performance Forum 2 28 May 2008 11:43 am
Replacing Timing belt: Engine support question cardana24 Tech & Performance Forum 4 21 Mar 2008 07:55 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
