Starter Smoking
Old 13 Jan 2011, 03:55 pm
Default Starter Smoking
This morning I was getting ready to go to school when my 2006 PT 2.4L non-Turbo, auto trans wouldn't start. The engine kept turning but never started, then my starter began to smoke. I assume that I need a new starter. If anyone else has any other insight let me know. I was also looking for that repair manual on the site but can't seem to find it anywhere, all the links for it appear to be dead
Old 13 Jan 2011, 04:06 pm
Default Re: Starter Smoking
As far as the repair manuals go, well, those were posted inappropriately as they bust copyright by doing that. See my PM.
As to your starter, have you had your car in deep water or deep snow lately? Have you had any previous starting problems? Has anyone ground the starter on the flywheel while the engine was running?
There are many factors that can cause your starter to have these problems, some can be very serious. Flywheel frozen up keeping the starter from turning is one of the worst, but not often encountered.
Old 13 Jan 2011, 04:54 pm
cruserdad1976's Avatar
but if the motor was turnning over like it normally does the question is why it did nto start
Old 13 Jan 2011, 06:39 pm
you haven't stated the mileage or if the timing belt has been changed.
my bet is the timing belt, especially if it turned over faster than usual.
Old 14 Jan 2011, 12:04 pm
The smoke might just have been moisture turned to steam - does starter still work now that it's cooled off? Did car start?
Bad starter?? jdmickies Tech & Performance Forum 8 06 Sep 2010 11:01 pm
rough idle and smoking jaci321 Tech & Performance Forum 3 23 May 2010 07:32 pm
Starter Modifications chasetag87 Tech & Performance Forum 10 26 Feb 2010 04:54 pm
Possible bad starter morrises Tech & Performance Forum 7 17 Jun 2008 09:07 pm
Smoking Tires are amusing PlatinumTurbo Stage Turbo Kits 9 06 Nov 2006 12:20 am
