Heater smell
  • 1 Post By discovering06
Old 16 Jan 2011, 12:10 pm
Question Heater smell
When the heater is in the full open position the air coming out smells like burning oil. I've opened the engine compartment and no obvious signs of burning oil. I recently changed the cabin air filter about 300 miles ago. This only happens when the heater is on, not the a/c. Any suggestions would be appreciated?
Thanks
rob302 likes this.
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 16 Jan 2011, 01:06 pm
SCBluePT's Avatar
Default Re: Heater smell
When I changed the cabin air filter on my previous car it did the same thing.It was just the new rubber around the filter heating up and it went away eventually.Maybe not your problem but that was the case with mine.
Old 23 Dec 2016, 12:15 pm
Thanks
discovering06, Did you ever determine the root cause? I have an 07 which I get a similar smell you have describe each winter when I start using the heat. I do not get the smell when running the AC in the summer.
Old 23 Dec 2016, 12:17 pm
Um this member has been absent for a long time (12 Nov 2016, 10:51 pm) and look at the date the last response was posted???
16 Jan 2011, 10:06 am
Old 23 Dec 2016, 12:26 pm
rob302's Avatar
he logged on two days ago. this might be the perfect guy to ask. i'd think in 5 years he probably found the cause by now.
Old 23 Dec 2016, 12:31 pm
I saw that but was looking at his response info. If he respond than maybe we can pick up the responses again. I have a feeling about the answer. it is not the first time some one changed there cabins filter and smelled "NEW" and strange things. Everyone's nose smells a little different.
Gasoline Smell coming in Heater Vents 2002 PT Limited MarcusO Tech & Performance Forum 13 18 Jan 2016 01:05 pm
Foul smell when turn heater on 06 pt kkrtype General PT Cruiser Discussions 8 03 Dec 2013 04:38 pm
I smell gas... mcjfender Tech & Performance Forum 1 05 Apr 2010 03:03 pm
GAS SMELL ?????? mjb457 Tech & Performance Forum 6 30 Oct 2009 12:34 am
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
