Transmission Pan Sealer That Actually Works?
Old 17 Jan 2011, 08:06 pm
Matt42's Avatar
Unhappy Transmission Pan Sealer That Actually Works?
I'm looking for suggestions for a transmission pan gasket sealer that actually works. I've tried the Permatex gray RTV with no gasket, per the TSM. It oozes ATF+4 out the lower rear edge. I've tried the Asian Auto standard gray RTV applied to a synthetic neoprene-like gasket. It oozes ATF+4 out the lower rear edge.
In both cases, I've carefully and religiously cleaned and lightly scraped the pan surface and the transmission surface with solvent, then alcohol (for the RTV). The scraping was light, just to scratch off the remaining RTV that wasn't vulcanized on and in the machining pattern.
The leak occurs where ATF dribbles down from the inner workings of the transmission, even after I've left the pan off overnight to drain. In the mere seconds between wiping the ATF off with a cloth wet with alcohol and slapping the pan into place, enough ATF gets onto the transmission mating surface to oil-up the surface, which then keeps the RTV from sticking. (RTV won't stick to even a thin coat of oil.)
This is really frustrating.
I'm old enough to remember using Permatex Number 2, which smells sort of like pine pitch. Will it work? How about spray-on copper coat, which has done marvelous stuff for me. Another last-ditch sealer has been Gasgacinch. Any thoughts on that?
Or is there some trick to getting that annoying ATF dribble to stop just long enough to slap the pan into place?
Thanks.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 18 Jan 2011, 08:21 am
Default Re: Transmission Pan Sealer That Actually Works?
Not sure but I intend to use High temp Permatex on the weekend, I will let you know. I dont know if it has anything to do with the residual run of ATF or the actualy surface and sealant. When rebuilt my motor over a few weeks I drained the transmission completely got ever last drop out. There was no ATF running down anywhere when I put the pan back on with Permatex grey. A week later the rear bolts and some on the side had drops of oil hanging on them.
Past experience with Neon transmission pans, being they are similar, some of the pan bolts were actually drilled up into the transimission and were not blind holes. Which meant that even if I put RTV around the hole the ATF would leak in from the threads and then out around the head of the bolts. The only way i got them sealed up was to use RTV high temp on the pan with the usual pattern around the bolts. Then apply RTV high temp to the threads of each bolts and torque down. I will check once my pan is off again if any of the pan bolt holes are not blind holes, if so I bet thats where it is leaking from.
Old 18 Jan 2011, 10:53 am
cruserdad1976's Avatar
i left my pan off for almo0st 2 weeks it dripped all over my shop floor and evn then wheni raised it back up it still had some small dribble and i am pretty sure the screw holes go all the way through mine seep but really does not drip
Old 18 Jan 2011, 07:59 pm
xwing777's Avatar
Look for an anaerobic sealant. These seal when there is not a presence of air. Most newer cars use this stuff only instead of gaskets. I think toyota was the first to use this but not sure. I had an issue with a leak on my truck and the toyota dealership sold me a tube of it (after paying way to much for it there i found out permatex makes it too, but for 1/5th of the price )
It worked very well and no leaks years later.
Old 18 Jan 2011, 09:00 pm
Matt42's Avatar
Aha! Leaky bolt holes and anaerobic sealants. Both make a lot of sense. Something to try if this last attempt didn't work out. Trying to recall, in my memory view, those rear bolt holes seem to go into the inner bowels of the transmission.
Anybody know what Permatex part number their anaerobic sealer is? SWAMBO is calling me for dinner. Lon day at work today, and I must not keep her a-waitin' a minute longer.
Thanks.
Old 18 Jan 2011, 09:05 pm
mityqwik's Avatar
Thumbs up Re: Transmission Pan Sealer That Actually Works?
i have had my trans. pan off 3 times because of this drip around the bolts or around the edges, and i have used what crysler said to use even used some high grade aircraft rtv no luck so the 4th and hope finale time 4 months ago i did what the manuel says not to i used a thin rubber gasket from NAPA auto parts and i have no more leaks or drips.so if the trans. starts to act up i know to go back to rtv.and i already know about the trans.pan helping to holding the filter on .so some say it is so some say not
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 18 Jan 2011, 09:12 pm
Just a thought, did you use the recommended bolt tightening procedure and the correct torque for the bolts?
Old 18 Jan 2011, 09:15 pm
mityqwik's Avatar
yes followed to a t. and the torque wrench was certifide at a calibration center.
Old 18 Jan 2011, 10:35 pm
xwing777's Avatar
from permatex's website http://www.permatex.com/products/aut...et_Maker_b.htm
Old 18 Jan 2011, 10:47 pm
Just a thought....
Would this work? 2001-2010 Chrysler PT Cruiser Automatic Transmission Pan Gasket - Transmission - Felpro 01-10 PT Cruiser Automatic Transmission Pan Gasket - 17851-07058344 - PartsGeek
Mine is leaking a little as well, thinking about this a solution.
Air Conditioner - R134a With Leak Sealer robinjoe General PT Cruiser Discussions 4 09 May 2008 07:38 pm
chrome sealer??? Jimbo The Detail Shop 2 14 Jan 2005 10:37 am
Gary's Chrome Cleaner/Sealer is GREAT! Gary04GT The Detail Shop 4 17 Jun 2004 08:33 pm
Chrome Cleaner/Sealer Gear_Head The Detail Shop 0 27 Apr 2004 12:00 pm
This is the factory headlamp sealer TripleJackInGA Exterior & Interior Styling 3 23 Jul 2003 02:17 pm
