Oil Pressure Switch
Old 18 Jan 2011, 03:50 pm
Default Oil Pressure Switch
I have a 2007 pt with on oil leak coming from the Oil pressure switch. Dealer says $100 to replace. Autozone has part for $12. The swith screws into the block on the back side of the engine and is a pain to get at (I tried yesterday... and gave up after I could only get my finger tips barely on it). It would be a breeze if the half axle wasn't in the way.
Has anybody replaced this in and if so how did you get the job done?
Old 01 Apr 2012, 02:12 pm
Default Re: Oil Pressure Switch
if you remove the two screws that hold the power steering cooler you can get to it you will need a specil scoket
Old 01 Apr 2012, 02:23 pm
I've read where 1 or 2 owners got to it from the top by removing the air filter system. I believe it takes about a 27mm deep well socket (don't quote me on that).
OK, here's the thread where they got to it from the top.
Oil Pressure Sensor ,What tool is needed
Old 01 Apr 2012, 08:23 pm
mdfrodolives's Avatar
Dad, I paid the dealer to do it. I really like to see what I'm doing when I'm wrenching. The dealer also had a lift and went at the oil-sending unit from below. They charged only $65.00 for part and labor, though.
If you get a new unit and put it in yourself, make sure you get a genuine Mopar oil-sending unit.
Tim
Old 28 Dec 2012, 05:40 pm
I recently replaced my 04 PT non turbo oil sensor switch due to it leaking and appreciated the tips left in this forum.
I did not have to take out my battery, but taking out the air filter housing is a must. I was never really able to "see" the entire sensing unit while I was doing the replacement but the hand room is ample once the items are out of the way.
When removing the electrical connection take special care as I broke mine in the removal process and was fortunate to find a used replacement connection at a local junk yard for $10 compared to $53 at the dealer (not a stock item). I cannot tell you positions of the sensor connections because depending on installation it can be positioned at any point of a 360 degree radius due to screw-in sensor. A tip is to try to press (and pull the connector at the same time) the release mechanism near the wire end of the connection regardless of the position of the Red locking mechanism. If it doesn’t' come off then push the Red locking mechanism in the opposite direction and repeat the above instructions.
I was able to fit a 1-1/16" deep socket on my new sensor ($13 from Auto Zone, same price at dealer) and decided to use it to remove the old one since the fit was snug. It worked for me so I didn't purchase the 27 mm deep socket. I also had to use an 3" extension to get the most ratcheting room.
A/C Low Pressure Switch, where is it? KJEandLWE Tech & Performance Forum 37 21 May 2017 11:57 am
oil pressure switch shaggypt Tech & Performance Forum 2 06 Jun 2010 07:43 pm
OIL PRESSURE SWITCH ??? badtxguard Tech & Performance Forum 2 25 Sep 2009 05:13 pm
High Side Pressure switch smithcruiser General PT Cruiser Discussions 4 08 Aug 2009 08:24 am
A/C Low pressure switch rhohmann General PT Cruiser Discussions 3 18 Jun 2009 11:50 am
