Engine light came on today with a p0301 error code...says its a cylinder 1 misfire detected...does that mean plug,wire,both?...thanks
We can't answer that question because the code only points in a general direction. It COULD be the plug or wire or vacuum leak or head gasket or burnt valve or......
Easiest thing to do is take both the plug and wire from cylinder #1 and swap them with cylinder #3. Clear the code by taking off the negative battery cable off for 5 minutes. Put everything back together and see if the code comes back as P0303 (misfire in cylinder #3). If it does, it narrows down the fault as either the plug or wire that you just put in #3. If it's been awhile since you changes plugs & wires, might as well do a tune up and put in everything new.
Rules of the forum have been updated as of *07/07/2019* Please read them over. - All decisions by the Moderator are semi-permanent, can and may be changed at his discretion but definitely will be the final word. Any action performed by the Administrator or Moderators are not to be discussed on the forum. |
Thread Tools | |
Display Modes | |
is it an error Code or something else | saraPT04 | Tech & Performance Forum | 5 | 08 Oct 2010 02:46 pm |
Error Code 320 | okla2001pt | Tech & Performance Forum | 1 | 17 May 2010 12:42 pm |
P0301 Code even with new plugs and wires? | ottoman | Tech & Performance Forum | 3 | 10 Feb 2009 09:07 am |
error code P0301 | chicagocruiser | Tech & Performance Forum | 4 | 28 Dec 2008 06:06 pm |
Error Code | saldagus | Tech & Performance Forum | 2 | 25 Nov 2008 09:51 pm |
