P2074 & P0122 Codes
Old 24 Jan 2011, 01:10 pm
Default P2074 & P0122 Codes
On my Gf's PT Cruiser she is getting codes for P2074, Map Sensor Throttle Position Correlation at load, and code P0122 TPS/Pedal position sensor A circuit low Input. It started with the engine light coming on and off intermittent, then we noticed that a minute or two after the car starts up the cruise control will not cut on. (If you cut it on with in a couple minute os start up it works fine through the duration of the trip). Also, sometimes when you let all the way off the gas the car jerks a bit. It jerks right before your all the way off maybe in that last 5% or so. I was wondering what could be causing these two codes and these issue's?
Old 24 Jan 2011, 07:19 pm
Default Re: P2074 & P0122 Codes
Just a guess, but I'd say your TPS (Throttle Position sensor) could be the cause of your problem. It's on the side of the throttle body, pretty easy to take off and replace. If you do decide to buy one and replace it, ONLY buy a Chrysler part, not one from an aftermarket parts store. Auto stores sell junk for electrical parts and although you'll pay more at a dealer, the part are good.
Old 24 Jan 2011, 07:34 pm
Thanks that was my first thought with both of the codes being thrown. Do you know of theres anyway to check to see if its bad without buying a new one first. (hooking a multimeter up to check output or something along the lines of that?)
Old 24 Jan 2011, 08:01 pm
just buy the new one, toss it on, if it doesn't fix the problem take it back lol.
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
Old 09 Feb 2011, 01:43 am
I replaced the TPS and the check engine light went off ad ran fine for about week. including a long trip of a couple hundred miles. then tonight the light came back on and started jerking again. I was wondering if there could be something causing the sensor to go bad or another cause of this problem.
Old 16 Feb 2011, 01:43 am
Any Idea's?
Old 16 Feb 2011, 05:46 am
When you replaced the TPS, did you replace it with a part from Chrysler or an auto store? We've heard time and time again that electrical parts from aftermarket auto stores either don't work at all or have a high failure rate.
ERROR CODE P2074 spinner Tech & Performance Forum 5 30 Jul 2016 06:00 pm
code p2074 interrex General PT Cruiser Discussions 8 08 Sep 2011 03:37 pm
shaking today stepping on gas p2074 + p0122 PTC06Peet General PT Cruiser Discussions 2 22 May 2009 06:07 am
now got codes p0138 and p0122 PTC06Peet General PT Cruiser Discussions 9 18 Apr 2009 12:39 pm
2004 GT with error code P0122 deborrini General Turbo Discussions 4 03 Jul 2007 07:19 pm
