Still getting a P0304 Fault Code?????
Old 24 Jan 2011, 03:39 pm
Default Still getting a P0304 Fault Code?????
Hopefully someone can help me out. I have a 2008 Cruiser and the check engine light came on so I took it to my local Chrysler Dealer and they said I need a tune up(change plugs, wire) and the code was P0304 and they wanted to charge me $480!!! I told them I can do this myself, well took the car home and changed the spark plugs and wires and erased the code. Well drove the car again later on the next day and check engine light comes on again so I took it to the auto parts store so they could let me know the code and again it was P0304. So I decided to change the coil also hoping this would solve the problem, well it didn't. Light keeps coming on and I have erased the code each time I make a change by removing the battery out of the circuit for at least 10 minutes. I have change the intake manifold gaskets and the MAP sensor also, but the P0304 codes keeps coming back like a scarey night mare.
Does anyone know whats going on with my PT???
Old 24 Jan 2011, 03:50 pm
cruserdad1976's Avatar
Default Re: Still getting a P0304 Fault Code?????
isnt a 304 the cam sensor???
Old 24 Jan 2011, 04:25 pm
turbosnail7's Avatar
P0304 is an engine missfire in the 4th cylinder.
it could be poor fuel quality what kind of fuel are you using?
Bad Injector
Bad EGR valve
and low compression
just some ideas.
2003 PT Cruiser GT Autoshift
1986 Toyota Pickup 4x4
1989 Honda Hatch Si
2003 Polaris Predator 500
2001 Yamaha YZF R6
Old 24 Jan 2011, 04:50 pm
Kawizx9r's Avatar
Compression test?
Kawi is a friggin genius!
Old 24 Jan 2011, 05:01 pm
Originally Posted by Kawizx9r View Post
Compression test?
compression/leakdown test because of the fact that it is a misfire on cylinder 4 only it could be a bad/burned valve
1989 Honda Hatch Si
2001 Yamaha YZF R6
Old 24 Jan 2011, 09:32 pm
Kawizx9r's Avatar
I meant to the OP.
Didn't read your post or any other post before saying anything
Carry on!
Old 24 Jan 2011, 11:20 pm
XmasDVD's Avatar
Send a message via Skype™ to XmasDVD
..you can buy a $99 'code checker' and plug it in and get the code yourself.
Amazon.com: Actron CP9125 PocketScan Code Reader: Automotive
** CHECK OUT MY PT GALLERY **
Old 25 Jan 2011, 01:47 pm
Changed injector #4 also. Still having issue.
Guy did a compression test and he said it was ok. I wasn't too pleased with him though. I may have to just take it in to the dealer and have them figure it out. Still under warranty till 72,000 miles, already at 69,000. Hopefully my extended warranty will cover it since it seems to be a bad/burnt valve. May just have to eat the $100 deductible.
Thanks for all the input!
Old 26 Jan 2011, 02:34 pm
Swap wire and plug with another cylinder and see if it moves. Possible you got a bad plug/wire - happened to me once.
Old 28 Jan 2011, 07:24 pm
It could be a burnt valve my 06 had one @42000 miles ,code PO303 paid almost 900.00 dollars. Runs great now.
Check engine code P0304 Gary Mick Tech & Performance Forum 28 04 May 2014 06:26 pm
p0304 code manzanman Turbo Performance 6 04 Jan 2013 05:56 pm
“Please” does anyone one have any solution to code P0304 KGWilder Tech & Performance Forum 4 15 Dec 2010 01:02 pm
P0304 code Engine Light On wedge22 Tech & Performance Forum 1 23 Feb 2010 07:02 am
Error Code P0304 Max Tech & Performance Forum 2 30 Mar 2009 03:46 pm
