REVERSING LIGHT - NOT WORKING
Old 25 Jan 2011, 04:00 pm
Default REVERSING LIGHT - NOT WORKING
I have a 2001 2.0L manual PT Cruiser, the reversing lamp has stopped working, not the lamp/bulb (swapped with the fog light which was and is still working with the reversing lamp bulb in it), does anyone please have any idea as to why, or as to where the switch is located (peferably not in the gearbox!) so that I can check the current etc, or is it on a fuse that is solely for the reversing lamp that I have missed.
Old 25 Jan 2011, 04:59 pm
Default Re: REVERSING LIGHT - NOT WORKING
You have a 2.0 liter PT so you live in Europe. The wiring is probably quite a bit different that the U.S. cruisers where we only have the 2.4 motors.
Just in case some things might be the same, you might have a fuse box in the interior of the vehicle. On the left hand drive U.S. cruisers it's beside our left knee. Don't know where it is on your car, but if you can find it, the No#6 fuse is for the back-up (reversing) lights.
The schematic does show a back-up lamp switch but it doesn't say where it's located, but I'd look around and check the fuse first.
Old 30 Jan 2011, 06:27 pm
Only 2.0 here and 2.4 diesels, will have a look in the light. Many thanks.
Old 07 Feb 2011, 10:12 am
Unfortunately tyhe fuse (no 6 10amp) is good, will check all others, but looks like a visit to the dealer!
Old 24 May 2016, 03:05 pm
hi
i have same issue but little ddifferent in my case only one of the rear light is not working other one is fine !
(changed the lambs that wasnt the issue)
what do u think is the problem ?
thanks.
Old 24 May 2016, 04:00 pm
Best bet is corrosion in the bulb socket. Pretty easy to take out the rear lamps and test the wiring and also look for any corrosion that would stop the bulb from making good contact.
Old 28 May 2016, 03:43 pm
Had the same problem with my 2.2CRD - measured 12v at the socket, swapped over the housing for the fog light - still nothing
Assumed it was the switch in the gearbox but couldn't be arsed to find it so frigged in am LED bulb with the assistance of wire and glue and it now works fine (apart from the fact I get the beep beep beep that the bulb is broken, which I have now convinced myself that it's an audio aid that I am in reverse)
HTH
Tags
lamp, reversing
Dash light not working.. wompus General PT Cruiser Discussions 2 02 Jan 2011 07:12 pm
dome light switch on S/W not working outfit Interior Accessories Forum 0 13 Dec 2010 04:17 am
squeaking noise when reversing supgrrl Tech & Performance Forum 2 02 Sep 2009 10:31 am
high brake light not working bobcatss66 General PT Cruiser Discussions 3 10 Mar 2009 01:32 pm
Gear Shift Light Not Working memejane Interior Accessories Forum 2 30 Nov 2007 07:55 am
