Spark Plugs for 2001 ??
Old 25 Jan 2011, 08:23 pm
Arrow Spark Plugs for 2001 ??
I have a 2001 PT Limited - not the Turbo engine. What are the best spark plugs to use on this model? I have 98,000 miles on the vehicle of which 90% was city miles.
What is the best spark plugs to use?
What else is there good to change as a tune up item at this point. Without breaking the bank.
Thanks for your help.
Old 25 Jan 2011, 09:09 pm
Default Re: Spark Plugs for 2001 ??
I take it you've changed the plugs before this at your mileage? What did you use then and why not go with the same?
Did you change plug wires at the last plug change?
If by any chance you bought the Pt used and don't know the history, then plugs AND wires is the way to go. A lot of us used Champion Double Platinum #7570 and as for wires, almost anything will do except Chrysler's normal wires that duplicate what originally came with the car. The MOPAR Performance wires are good, I've used them at my first change and they lasted a long time without a problem.
Now for the big question; have the timing belt been changed. They are due right now at your mileage and depending on your bank (which you don't want to break) it will run you anywhere from $800 to $1200 depending on the hourly rate for labor from the person you have change them. Along with the belt, the water pump, belt tensioner and both drive belts should be changed also. They would be included with the price I quoted.
Old 25 Jan 2011, 11:32 pm
what about E3 plugs? any good?
Old 26 Jan 2011, 09:05 am
You asked a question, got a answer, so now you are wondering if something is better? Why didn't you do a search and find out your answer?
Old 26 Jan 2011, 09:14 am
themadgreek187's Avatar
i have autolite iridium plugs and premium wires in my 01 non-turbo cruiser. running like a champ. make sure u gap properly.
Old 26 Jan 2011, 12:14 pm
Very good choice for an NA PT.
Old 26 Jan 2011, 01:23 pm
Very expensive choice. IMHO irridium plugs are overpriced and overhyped. Oh well, the name "irridium" sounds cool. For the na PT I'd go with the Bosch doulble plats. Great plugs and they last a long time.
Old 27 Jan 2011, 09:08 am
i got everything from advanced auto with coupon out the door $37. i'll take that all day long.
Old 27 Jan 2011, 09:36 am
tryingbe's Avatar
I'd go NGK copper. Under $10.
85 GLH
Watch out for anchor engine mounts!!
Old 27 Jan 2011, 10:51 am
cruserdad1976's Avatar
I put the E3's in my 06 na and they did ok couldnt tell any diffrence in mpg or on power but i didnt really ecpect to going back to the bosh plugs next change
E3 Spark Plugs Ceit Turbo Performance 4 27 Nov 2008 11:09 pm
Spark Plugs voblak2 Tech & Performance Forum 1 10 Sep 2008 12:47 pm
Spark Plugs jingks Turbo Performance 6 31 Jul 2008 10:28 am
Spark plugs discovering06 Tech & Performance Forum 3 19 May 2008 10:36 pm
spark plugs MNShaleCruiser Tech & Performance Forum 5 12 Dec 2001 03:17 am
