High RPM fault
Old 29 Jan 2011, 10:34 am
simplympd's Avatar
Default High RPM fault
Hi! Newbie here, please be kind!
I have an '03 2.0L manual. Recently, I have been suffering an RPM runaway fault whenever I put the clutch in.
For example, in a queue at a roundabout, idle at 1000... increase to 1500 with pedal and lift clutch to move forward in queue and car behaves normally. However, as soon as I put the clutch back in the RPM either freezes or climbs anywhere up to 3000 for a good few seconds before dropping back to normal idle...
I do not appear to have any stiffness in the cable side of it so can only assume it's an electrical fault...
This happens virtually every clutch in event, no matter what gear or RPM...
Any advice much appreciated!
Old 29 Jan 2011, 11:33 am
UptownSport's Avatar
Default Re: High RPM fault
My vacuum booster hose got oil soaked, and fell off the manifold.
For such a huge vacuum leak, the thing ran pretty good ...
Perhaps there's a vacuum hose off yours or something.
Old 29 Jan 2011, 11:41 am
simplympd's Avatar
Interesting response... I do have a collapsing PCV emission hose... I was under the impression that only affected idle speeds...
I have one on order...
Old 30 Jan 2011, 11:08 am
simplympd's Avatar
I have to confess, I'm still at a loss to explain how exactly a crushed vacuum hose would produce the symptoms I'm suffering.... Any experts out there?
Old 30 Jan 2011, 11:58 am
I'm no expert but maybe one of these will help....
Engine Vacuum Leaks
RANDOM MISFIRES
Vacuum Leaks Repair Questions Answered By Certified Technicians Free
Old 30 Jan 2011, 12:39 pm
simplympd's Avatar
Thanks for the links Crewzin! I'm off to check them now... will report back!
Last edited by simplympd; 30 Jan 2011 at 12:40 pm. Reason: to spell Crewzin's name correctly! soz!
Old 31 Jan 2011, 12:22 am
mdfrodolives's Avatar
I was one of the idiots who purchased a Plymouth (or was it Chrysler? I can't really remember) Laser. It was a manual and had a Bosch Computer Brain. Anyway, I got rid of it in a year's time, mostly because when I would put in the clutch (not always, but sometimes), the idle would go as high as 4000 RPM's. This would also happen when I'd start the motor. The problem never occurred while in gear, however. The dealer pretended as if this was not a problem, since the engine would never do this high rpm thing whenever I took it to them for an answer.
The reason I bring this up is this: maybe you have a problem with your computer that is similar to what I encountered with another Chrysler in the early '80's.
But let's just hope it's a collapsed hose ....
Tim
Old 31 Jan 2011, 04:07 am
simplympd's Avatar
Thanks for your post! I'm pretending it can't possibly be the ECU at the moment...
Old 31 Jan 2011, 09:51 am
If one hose is failed, perhaps other have failed as well.
It sounds like the little idle motor is controlling the idle as it's supposed to,
when it gets out of control, the motor closes down, then as it's driven
returns to a default position, anticipating this is where it should be idling
when the throttle's closed.
Newer vehicles may have PWM valves, it's different than the old motors,
works like an injector (Controls air instead of fuel or something like that)
In any case, fix what's obviously wrong and give it a good visual.
Guys were also talking about manifold gaskets, but don't think they'd be
in the 'massive leak' category
Old 31 Jan 2011, 02:42 pm
You are probably looking at a bad TPS (throttle position sensor) or the wiring. This has been a problem for the PT and the Neon SRT-4. Most of the time it is the wire going into the TPS. If that is the case you'll need to replace the harness. You can usually tell if it is the wire by wiggling the wire and see if you get runaway rpm's. This can be embarrasing when you pull up to a stop and the engine is racing like crazy.
Is it my fault? My PT is broke? PT Lilly General PT Cruiser Discussions 21 29 Aug 2012 09:35 pm
Fault Codes sscanlan Tech & Performance Forum 11 29 Sep 2010 09:53 pm
SKIM Fault? hobbit Tech & Performance Forum 20 28 Apr 2010 04:27 am
P0138 Fault irishman331 Tech & Performance Forum 19 01 Aug 2009 11:14 pm
Fault code RossiePT General Turbo Discussions 8 28 Mar 2004 10:52 pm
