Hard Starting after filling Feul tank
Old 29 Jan 2011, 08:32 pm
Unhappy Hard Starting after filling Feul tank
Got a 2005 convertable, non turbo. Runs great except after filling fuel tank, cranks along to start and will die if rpm's not kept above approx. 12-1500. after approx 2-3 minutes it will run fine. Check engine is on. Have had check for codes, not any help. had smoke test on fuel emission system, no leaks. Been told needs new gas cap twice,. no help. When check engine light is cleared takes 200 to 500 miles to come back on. Please help
Old 30 Jan 2011, 12:13 am
Kawizx9r's Avatar
Default Re: Hard Starting after filling Feul tank
Doing the 'key dance', what code do you get?
It could help us to better tackle your issue.
Kawi is a friggin genius!
Old 30 Jan 2011, 06:23 pm
Smile Re: Hard Starting after filling Feul tank
Ok just did the key dance.....got code PO456.
Old 30 Jan 2011, 06:44 pm
Evaporative Emissions System - Small leak detected.
according to google.
Old 31 Jan 2011, 11:23 pm
We already knew what the code was.....been in 2 local shops....both have smoke tested...NO sign of leak, I was present for both tests. Looking for other ideas to try. I'm a heavy equipment mechanic by trade. We live in a rural area, so stealership is out of the question. Any other idea's. Thanks
Hard Time Starting tina184 Tech & Performance Forum 2 24 Nov 2009 08:28 am
Hard starting 180HP turbo sawdust123 General Turbo Discussions 12 12 Sep 2005 10:22 am
Hard Starting KruznMyWay Tech & Performance Forum 4 24 Jul 2004 01:18 am
Hard starting turbo GGJaguar General Turbo Discussions 6 05 Jun 2004 03:39 pm
PT Hard starting PTCumming General Turbo Discussions 7 16 Apr 2004 12:36 pm
