Also, make sure you did not put the filter back on "dirty-side-up". |
I have a 2003 DC2 (GT). I added a K&N drop-in and removed the white collar silencer and masked the snorkel holes with electrical tape. The car was more responsive to throttle changes (I pass and slalom a lot) and the engine felt smoother. I did not expect to really feel a difference--a pleasant surprise. I love hearing the sound of vacuum in the morning, too. My question is this: would an aftermarket replacement (like the Typhoon) yield better results? My stipulations: "Negligible" versus "noticeable" is irrelevant. Cost is irrelevant. Value is irrelevant. My goal is to have everything tuned in the best possible manner, for performance and longevity. I also want to learn and tinker (yes, my newfound hobby). I plan on upgrading to Stage 2 whenever it becomes available. Now, my musings... Addressing "overly restrictive"--I prefer to eliminate all restrictions possible ("Breathe! Breathe damn you!" heh). So, suffice it to say that the third silencer needs to go and the fewer bends, the better; 100% Mandrel bent tubing seems to be in order. Temperature--I like the stock airbox for this reason: it is completely sealed and is plugged right into the wheel well scoop. The downside: bends and possible restriction. Questions: 1. Is the I.D. of the snorkel ample for the volume of airflow at the upper end? 2. Would merely removing the snorkel (and in turn increasing the airbox's opening I.D.) provide a less restrictive, usable airflow? Would potential warm air intake negate that? 3. Also, would there be a benefit (less restriction) from not having the snorkel protrude so far into the airbox? 4. Is the airbox pressurised at all from the snorkel, possibly due to velocity of incoming air? (I really have no idea of the volume of air being pulled by it.) 5. How much warm engine air is getting pulled into the unsealed "cold-air" intakes? Their design seems self-contradictory. It seems that an aftermarket intake with the filter almost directly above the wheel well opening and sealed from the engine bay would be the best, most efficient route. 6. Ultimately, I suppose, it boils down to this: Is the forced induction system (turbo) getting what it wants, when it wants no matter what? I have the belief that the turbo belittles the effects of a tuned intake, but can still benefit from it, albeit much less than an NA engine would. (But, for me, cost-benefit is not a factor, plus there is just having the knowledge.) 7. Did my current modifications hit the "law of diminishing returns"? (i.e. Would any other setup perform identically to what I have now?) I appreciate any inputs. I think answering these would produce The Definitive Guide To The PT Cruiser Air Intake. [ ] |
I do want one. You have created a marketable item, run with it. |
PainT, Rolo,
I now have the new clean K&N drop in filter and it runs better in acceleration and passing but still have groan. Rolo, All I did was unclip the stock intake cover replace the filter and reclip the cover. I suppose the breather hose my have come a little lose, but don't know why? PainT, I have checked the seating of the cover three times and seems to be fine. I will have to check the piping. One more thing when I first took the cover off the tubing from the cover to the engine was stiff and nows is easy to move with no stiffness. Could this have caused the sound difference. Im a newbie when it comes to most engine mods but after working it for a while, can understand. I know that they tubing is rubber based and is made to be pliable.
KingKole02 ![]() SW Florida PT Cruisers Secretary/Treasurer/Webmaster www.swfloridaptcruisers.com Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics For cruiser pics go to: http://ptcw.truckmoxie.com/mygallery.ten?id=3464 http://smg.photobucket.com/albums/v8...0in%20my%20PT/ For my personal page, visit http://www.kingkole02.com http://random-input.blogspot.com http://www.ptcruiserweekly.com www.WeKnowDna.com DNA Guided Nutrition www.TheDnaDiet.info Fox 4 Study Report |
Since you only messed witht the top half, the breather hose is probably fine, but assume nothing. (I took the whole thing out to inspect/tinker/clean/shine.) It is connected to the lower part of the airbox under the intercooler/throttle body hose and impossible to see unless you are looking for it. I hope dust is not getting into your impeller... [xx(] |
wheelguner, don't take this wrong, but a 10 hp increase by adding just a "cold air intake"? If this is indeed true, this means that these cars are being severely air starved. Was the airbox on your '02 Cruiser the same as those found today or has there been there been some major changes since that timeframe?
Thanks for the info! |
My PT is an 03' Touring non-turbo. I will still follow your recommendations. Thanks for your help.
read the post under turbo performance you need this info.
jim |
Has anyone seen or installed any of the 12volt blower fans that are/were advertized on Ebay. They claim that it bolts up to the standard intake and forces more air to the intake for more zip. Cost is around $100. Looks like they are using a modified bilge blower off of a boat.
Thanks
2002 "Unlimited" Edition, Supercharged, Hurst, FlowMaster, Airaid & Retro Look |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Codes | skylight | Tech & Performance Forum | 6 | 07 Apr 2007 02:19 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| Installing Injen Air Intake.. Quick question.. | wyzard | Tech & Performance Forum | 2 | 28 May 2005 11:55 am |
| K&N Typhoon Intake system for PT Cruiser turbo GT | KN Filters | Turbo Performance | 1 | 06 Jun 2003 12:37 pm |
