Loose Bolt
Old 31 Jan 2011, 03:49 pm
Default Loose Bolt
I've been the proud owner of a PT for over a year now, and haven't had any issues with the car up until recently. I'm certainly not a genius with cars or anything but a bolt in the upper passenger side of the engine keeps coming loose as I drive. Oftentimes, it loosens up so much that it begins grinding into the freon tank. I'm probably going to have to replace the freon tank, but is there anything I can do to stop this bolt from coming loose besides tightening it every few days??
Old 31 Jan 2011, 03:53 pm
Default Re: Loose Bolt
what is the bolt holding? maybe try a lock washer.
Old 31 Jan 2011, 04:13 pm
Spray it with carb cleaner to de-grease it, dry it and a dab of loctite on threads.
Old 31 Jan 2011, 08:42 pm
only one I can think of where there is a moving part rubbing up against the stationery A/C dryer tank is the alternator locking bolt. If the bolt is that close to the dryer tank then you have used up all of the adjustment on the alternator belt. I would recommend replacing the alternator belt, this will pull the adjuster bolt far away from the dryer tank.
Just a guess until we have more info on the bolt you are referring too.
Tags
engine noise, performance, problem, technical
loose center cap LNBNDN Wheels, Tires, Suspension 1 21 Sep 2010 01:51 am
Aux port loose!!! ptguy69 Sound and Security Forum 4 13 Jul 2010 08:23 pm
Which bolt is the tensioner bolt on the alternator? bjagd02 General PT Cruiser Discussions 6 23 May 2010 10:57 pm
Loose Steering???!!! Unseenspirit2002 General PT Cruiser Discussions 10 21 Mar 2008 10:15 am
LOOSE LUGS?? soonercruiser Wheels, Tires, Suspension 5 17 Jan 2008 11:01 pm
