Keys out of the ignition, engine still running...
Old 31 Jan 2011, 09:19 pm
Default Keys out of the ignition, engine still running...
Hi all i just had quite the experience with my PT this afternoon. I turned off the car and pulled the key from the ignition only to have the engine continue to run. After a bit the engine sputtered and turned off but then some of the lights on the dash stayed on. I tried to start the car back up but it wouldn't turn over after that. Does anyone have any idea what is going on with my car? Its stuck in a parking ramp for the night and i'd love to go retrieve it. Oh and when i left the lights on the dash were still on as if it were running. Thanks for any tips anyone might have!
Old 31 Jan 2011, 10:41 pm
Default Re: Keys out of the ignition, engine still running...
I did some looking around on the internet and found this article. It seems to fit the problems that my PT is having. Now for my next question: Does anyone know where the high speed fan relay is in my 2001 PT? And how might I go about Disconnecting it to check if that is the reason my car is acting up?
Here is the link for the article I came across in case anyone else has this gremlin crop up in their car.
PT Cruiser's engine won't shut off Business SalemNews.com, Salem, MA
Old 01 Feb 2011, 08:24 am
The high speed fan relay is in the PDC (Power Distribution Center) or black box located in the engine compartment under the air filter. You can swap it for any one of the other exact size relays (horn) to see if it's working. After swapping, blow the horn and if it works, the relay is good.
Old 01 Feb 2011, 08:51 am
My hunch is your ignition switch/wiring going to it. You have tilt steering? Try tilting wheel and see if symptoms change (pinching harness).
Please do let us know when you get it fixed.
Old 01 Feb 2011, 09:14 am
Just saw this -
" He thinks my ignition cylinder is jammed or broken because even when you take the key out, everything stays on"
ignition cylinder jammed/broken?
Old 04 Feb 2011, 05:22 pm
Originally Posted by quicksilverdon View Post
Just saw this -
I have had the ignition key assembly fail in the past on 2 Chrysler products.
Both times It was indeed the tumbler assembly. I was able to remove the key in the off position, the car simply would not shut off.
I ended up pulling the coil wire to kill it and disconnected the battery lead to shut off the power until I was ready to take it to the dealer.
BTW, a word of caution, those high energy ignitions still shock you even if you use wood or insulated pliers to pull or push the wire off.
This was a product of to much JUNK on my key-rings. The combination of daily road bouncing, rattling and weight of trinkets killed the tumblers.
The dealer said its common especially of women?? He claimed we put to much junk on the key-rings. REALLY, No Really
keys corvairbob General PT Cruiser Discussions 22 05 Feb 2013 10:15 am
Keys. oldseabee General PT Cruiser Discussions 5 31 Jan 2010 06:24 pm
HIDs will not work with engine running. HELP PLEASES VampCruiser Exterior Accessories Forum 4 20 Jan 2009 09:56 pm
PT runs without keys Stalled Tech & Performance Forum 3 19 Jul 2008 10:37 pm
HELP! Key's Are Out, Engine Still Running! mentrc Tech & Performance Forum 0 04 Oct 2002 02:53 pm
