PCV valve.. Photo of that part??
Old 02 Feb 2011, 11:11 am
firebirdcabrio's Avatar
Question PCV valve.. Photo of that part??
Any one has photo of PCV valve? What could be fault when that part is worn?
Old 02 Feb 2011, 11:31 am
cruserdad1976's Avatar
Default Re: PCV valve.. Photo of that part??
a PVC dosent get "worn" it gets plugged up it is the crankcase breather so when it cant breath it cant return the oil back to the engine they are cheap and usually pretty easy to replace
Old 04 Feb 2011, 09:16 pm
BladeRunner's Avatar
When installing a new PCV don't over tighten it! I recently changed mine and there was some oil "weeping" around that fitting, after a closer look I found that someone had tightened the one that was in there to the point that a small crack had formed
That was where the oil was leaking. I sealed it with some high temp silicone and it seems to be Ok so far. Just remember the intake is plastic! The PCV looks like it has a pipe thread...so go easy.
Old 05 Feb 2011, 10:22 am
I posted these awhile back, but I'll put them up again. The L-shaped PCV is for the turbo PT.
Jerry
Old 05 Feb 2011, 10:36 am
Here's a couple of not very good pics of its location on the typical N/A. It attaches at the drivers side end of the cam cover. It's under the TB intake hose. You can also see the catch can on the "balance" hose.
Jerry
Old 05 Feb 2011, 11:32 am
UptownSport's Avatar
Very top, center '01 N/A. Disregard Red arrows
Fun Photo Gallery YoungCruiserrr General PT Cruiser Discussions 5 28 Apr 2009 08:55 pm
Hi I need a photo favor careyk General PT Cruiser Discussions 8 06 Nov 2008 09:46 am
Testing new photo for sig TurboT Testing 0 02 Jul 2003 06:03 pm
photo dan32240 General PT Cruiser Discussions 5 01 Dec 2002 01:19 am
