Replacing Camshaft
Old 05 Feb 2011, 09:14 am
Default Replacing Camshaft
I am replacing my camshaft in my 2001 Pt Cruiser w/o turbo. Does anyone know the torque spec and the bolt pattern for the cam cover caps?
Thank you
Old 05 Feb 2011, 09:52 am
UptownSport's Avatar
Default Re: Replacing Camshaft
250 in lbs big, 110 in lbs small, 85 ft lbs on cam gears
Old 05 Feb 2011, 09:58 am
Thank you!! Is there any pattern?
Old 05 Feb 2011, 11:30 am
No. Do them incrementally, IOW- so the cam goes down slowly, evenly.
Make sure the 1/4 drill holes are up in the area with the Red arrows (disregard writing in pic)
Retard crank a few teeth so piston isn't at highest point
Old 05 Feb 2011, 01:46 pm
cruserdad1976's Avatar
I guess when you do 1 you have to do both???????
Old 05 Feb 2011, 02:42 pm
No. Guy's'll use a 2.4 cam on one side and a Neon on the other.
Only the front cap has to come off for both.
Old 06 Feb 2011, 08:28 pm
Actually the service manual says that when removing the cam to remove the two end caps first. They're referred to as cap no's. 1 and 6. Then remove the two center caps (referred to as no's 3 and 4). Then remove the remaining two caps (referred to as no's 2 and 5).
To install the replacement cam install the two center caps first (no's 3 and 4). Then install no's 2 and 5. The end caps (no's 1 and 6) are reinstalled last.
The M6 bolts should be torqued to 105 in-lbs
The M8 bolts to 20 ft-lbs
The camshaft sprockets to 85 ft-lbs.
All torqueing should be done in several sequintial steps
Make sure the crank is at around 3 notches btdc before starting to torque these caps down.
While you've got the cam cover off it would be a great time to drop in a DCR whistle.
Yes, you'll pick up a few horses by using the neon exhaust cam. It's been done many, many times.
This would also be a good time to install adjusable cam gears. I've found over the years that a good starting point would be around 3 to 4 degrees retard on exhaust and you'll probably end back at 0 change on the intake, but every engine is a little differant so it's best to dial it in on a dyno.
Jerry
Jerry
Old 23 Jun 2012, 07:41 pm
sorry to dig up an old thread but, the exhaust cam on my 01 cruiser broke. If I can change just this cam to the 2.0 neon cam would be great if it is cheaper and offers any performance upgrade. Did the OP finish this cam change or can anyone help me???
Old 24 Jun 2012, 01:20 am
Broke?
I'm sure I'd have one if you want, LMK.
Are the journals- Straight- or oil starved?
Old 12 Nov 2014, 02:27 am
What is a "DCR whistle?"
Camshaft sensor (again!) ABrown Tech & Performance Forum 21 29 Mar 2012 03:31 pm
Need to get bolt out of camshaft. Jooky Tech & Performance Forum 0 29 Mar 2010 08:06 pm
Camshaft pos.sensor replaced ....and??? mtnbktrek General Turbo Discussions 6 21 Jan 2010 07:56 pm
2 different Camshaft sensors??? 66CUDA Tech & Performance Forum 1 16 Jun 2009 10:35 pm
Camshaft Sensor ABrown General PT Cruiser Discussions 2 18 Jun 2008 07:36 am
