P0700 code & car won't start HELP!
Old 05 Feb 2011, 02:29 pm
Unhappy P0700 code & car won't start HELP!
i replaced the fuel pump because i had no fuel pressure yet there was power at the pump originally at 1st the scanner would not connect not that it is i'm getting P0700,P0463,P0562 the battery had been run down from girl trying to start it but i have sense recharged it engine cranks but won't run what are the chances i got a crappy fuel pump module from AZ?
Old 05 Feb 2011, 04:16 pm
Default Re: P0700 code & car won't start HELP!
P0700 is a generic code for trouble with the transaxle. A scanner needs to be used to pinpoint the exact problem.
P0463- fuel level sensor circuit high input. Not sure about that one. Could you have messed up the fuel level sensor while changing out the fuel pump?
P0562 SYSTEM VOLTAGE (ENGINE SIDE) TOO LOW
* The ignition voltage on the ignition feed circuit to terminal 7 at the ECM is controlled by the engine control module (ECM).
* If there is a voltage fluctuation and the voltage dips below the calibrated level,a system voltage Diagnostic Trouble Code (DTC) will automatically set
Old 05 Feb 2011, 07:03 pm
ok i changed the entire module from the tank not just the pump i reset the codes & nothing showing now i have fuel pressure now up to the fuel rail also have spark out of the coil to plugs yet still no start any ideas?
How to reset TCM? Error code P0700 crackdtooth Tech & Performance Forum 14 13 Apr 2015 07:06 pm
help I'm in mexico with code P0700 cintra07 General PT Cruiser Discussions 9 30 Jun 2012 07:48 pm
P0700 Error Code On PT Floyd Harris Tech & Performance Forum 6 08 Mar 2012 09:14 pm
P0700 code mash35231 Tech & Performance Forum 8 18 Oct 2010 06:01 pm
Beyond the P0700 code Vigilant32 Tech & Performance Forum 3 06 May 2009 04:47 pm
