Just cant figure it out (randomly dying as i drive)
Old 05 Feb 2011, 11:37 pm
Question Just cant figure it out (randomly dying as i drive)
I have an 02 limited manual and for some reason it just want to die. I will be driving usually between 1-45 mph and i will lose power and the engine dies, if im not on the clutch some times it will turn it self back over and others times it wont. i have to pull off the road (if im not stuck at a light) and try to get it to turn over, some times it will turn over after a few seconds other times it takes a few minutes. I have got a New batter, new battery terminals, new plugs, alternator is good.
Someone i was talking to had this same issue on another vehicle and they said it was some wires that ran from the computer were frayed?!?!?
Any one have any ideas?
Old 07 Feb 2011, 04:29 am
urimashe's Avatar
Default Re: Just cant figure it out (randomly dying as i drive)
you got new plugs, but did you get new wires?
2006 Base PT Manual Tranny, K&N drop in filter, Marine Blue paint, Name: Blue Monster, Body style: Path Cruizer... oh yea, seat covers? got em.
Old 07 Feb 2011, 09:56 am
Try to movethe battery cables - if you can move them, they aren't tight enough.
Old 07 Feb 2011, 08:50 pm
Yes new wires as well and the battery wires are tight no wiggle. When it die its hard to tell some times the radio stays on and so does the air. Its just no power steering and such.
Old 08 Feb 2011, 08:17 am
How about other ends of battery cables? You have a bad connection somewhere.
Do you have a lot of extra junk on with your keys? Might be ignition switch...
Old 08 Feb 2011, 10:03 pm
Matt42's Avatar
+1 agree
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 09 Feb 2011, 12:50 pm
No just a few key on the chain maybe 5. I had to have the old switch removed about a year ago and a new one add because it locked up. And the other end of the battery cable seems fine.
Old 10 Feb 2011, 02:13 am
Crankshaft Position Sensor - No sensor signal, the engine quits. Variable time to restart--possible poor connection between wiring harness and sensor.
Did you wash your engine compartment lately?
Let us know what you find for a solution to this issue.
Old 23 Mar 2011, 04:38 pm
Replaced the Crack shaft sensor and drives like new!!!!!!!!!!!
Old 23 Mar 2011, 05:23 pm
I hope you mean the CRANKshaft sensor or I'll have to let my friends over at the sub-station know your dealin.
Good catch BlueH20 but I guess being a Chrysler Service Manager for 8 years you sort of know a lot of the symptoms.
06PT radiator fan randomly stays on and drains battery mungor Tech & Performance Forum 2 03 Mar 2010 12:32 am
03 ptc randomly dies, electrical? snix Tech & Performance Forum 2 31 Oct 2009 11:25 pm
Alarm randomly goes off memejane Sound and Security Forum 5 03 Dec 2007 02:16 pm
