05 PT Cruiser Error Codes & Idles high
Old 08 Feb 2011, 01:34 pm
GA81PEACH19's Avatar
Angry 05 PT Cruiser Error Codes & Idles high
Ok since the cold wintery weather I have had ALL sorts of issues, first the signal lights and windshield wipers stopped working, dad changed fuses, then headlights and inside lights went out, called a mechanic, he changed the fuses, lights came back on, windshield wipers working, after that car wouldnt start, battery light came on, turns out he forgot to plug in some hose, car started..now when i turn on my headlights the inside (dash,radio lights) go off and inside dimmer doesnt work..did he get the fuses mixed up??
AND now the check engine light is on, car is idling high and wont down shift stays at constant speed (near 40mph) ..car was running perfectly fine before he touched it. So i took car to Autozone and they gave me error codes: 0700,0562, and 0888....I have already paid so much, I hope this is a simple fix...Does any of this seem like a major problem? or have the fuses just been misplaced??? Help!
2005 PT Cruiser Convertible Turbo
Old 08 Feb 2011, 01:45 pm
cruserdad1976's Avatar
Default Re: 05 PT Cruiser Error Codes & Idles high
well not to be the dark cloud but I dont think it is the fuses
did auto zone check the charging system???
Im nto sure what thoese codes are but hang on some body will have that answer
Old 08 Feb 2011, 01:54 pm
They checked the battery and the alternator and said they were good. So they said it may be a poor electrical connection.
Thanks so much, im hanging
Old 08 Feb 2011, 03:11 pm
Welcome Peach, put those codes in Google.
Old 08 Feb 2011, 03:46 pm
Kawizx9r's Avatar
P0562 System Voltage Low - someone will chime in. Are your cables to your battery making good contact?
P0700 Transmission Control System Malfunction - self explanatory.
P0888 TCM Power Relay Sense Circuit - if this relay goes bad, your tranny will be stuck in gear.
Kawi is a friggin genius!
Old 06 May 2013, 10:41 pm
compdr59's Avatar
Any resolution?
Original Owner 135k
2007 pt cruiser high idles tonybouc Tech & Performance Forum 10 04 Jan 2012 10:13 pm
error codes??? Turboguy85 Turbo Performance 2 22 Sep 2010 05:15 pm
no error codes lt4supr Tech & Performance Forum 4 14 Aug 2009 07:34 pm
Error codes mr.troy Tech & Performance Forum 3 16 Jan 2007 04:26 pm
