It's still running
Old 10 Feb 2011, 11:37 am
zip zip is offline
Default It's still running
Back in Sept. of last year , I came here looking for help with a coolant leak problem I was having..........I have never found the leak..........I put a 180 thermostat in it..........it still gurgles in the coolant recovery tank & I have to add a little antifreeze , but it keeps right on running...........starts right up on these single digit temp. mornings we've been having.......... IMHO , basically a good car.
Old 10 Feb 2011, 01:15 pm
meder2487's Avatar
Default Re: It's still running
I had a similar problem with the coolant gurgling and ultimately loosing coolant. It turns out that my radiator cap was not sealing completely and the system was not totally pressurized therefore the coolant was burning off and not actually leaking. I put a new cap on and it fixed the problem. It might be worth a try to pick up another cap and put it on and see if it helps any.
Don't Blink
Old 11 Feb 2011, 10:54 am
zip zip is offline
Radiator cap was the first thing to be changed.
thanks for suggestion , though
Old 11 Feb 2011, 11:11 am
Ratdaddy's Avatar
Could be a cold engine water leak..That is when the engine is hot the leak area seals due to heat exspantion and then leaks pressure & fluid when it cools down .. Try some leak dye...
Old 08 Oct 2012, 11:22 am
zip zip is offline
I changed the thermostat to a 180 , change the oil occasionally , check the coolant level , & put gas in it & IT'S STILL RUNNING..............I MIGHT get some new tires before the snow starts flying.
02 running a little hot... 02ptlimited Tech & Performance Forum 8 22 Jun 2009 09:47 pm
Car Not Running - Help plang1975 Tech & Performance Forum 8 28 Oct 2008 12:15 pm
up and running again careyk Canada PT Forum 1 19 Feb 2008 01:31 am
XM up and running CHROMEDCRUISER Sound and Security Forum 4 07 Jan 2005 07:22 pm
Anyone running NOS? MEXICANPT Turbo Performance 4 14 Jan 2004 10:03 pm
