P1864/P1865
Old 10 Feb 2011, 07:52 pm
Default P1864/P1865
My 2003 PT started up this morning and was able to get me where I needed to be, but when I came back later to go home it bucked a little bit like it was turning over wrong and gave me a P1864 and P1865 error code on the dash. I don't know how serious this is and would like some direction please.
Old 10 Feb 2011, 08:06 pm
Default Re: P1864/P1865
Welcome to the forum.
P1864 Torque Converter Clutch Circuit
P1865 4-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
I also found a non-pacific OBDII trouble code list with these:
P1864 Transmission Transfer Case Contact Plate Power Short To Battery
P1865 Transmission Transfer Case Contact Plate Power Short To Ground
Personally, I'd take the negative battery cable off for about 5 minutes. That will clear the trouble codes and reset the computer. Then see if those codes come abck up.
P1864 - Torque Converter Clutch Circuit? eflyguy Tech & Performance Forum 5 10 Feb 2011 07:42 pm
