Coil and spark plug wire question?
Old 12 Feb 2011, 04:49 am
Default Coil and spark plug wire question?
Hello I have a 2006 pt cruiser would you guys recomend msd performance spark plug wires and msd performance coil for this car??
Old 12 Feb 2011, 04:58 am
Default Re: Coil and spark plug wire question?
I have the MSD wires 8.5mm and they work great on my 06 n/a cruiser. The stock coil is more than suffient for output, unless you have a turbo. I used Champion double plats gap 0.40.
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 12 Feb 2011, 06:55 am
X2. Leave the coil alone unless your having problems.
Old 26 Mar 2011, 07:47 pm
flcruiser's Avatar
Exclamation Re: Coil and spark plug wire question?
For a non turbo PT Cruiser, what kind of spark plug wires you recommend and plugs. Mine is 03 with 103K miles.
Old 26 Mar 2011, 07:54 pm
Has your timing belt been changed yet. If not, your running on borrowed time before it goes. Do that first.
Champion Double Platinum Plugs #7570 gapped at .040in and any wires except stock from Chrysler. MOPAR Performance blue plugs are good.
As to the question in your other post of getting performance from the Non-turbo PT, the best you can do is keep it tuned up. It's a CRUISER.
Old 26 Mar 2011, 07:58 pm
WolfmanG's Avatar
here check this thread out. spark plug wires?????
-Danny Wolfman G
spark plug wire change help demon666 Tech & Performance Forum 6 19 Jun 2010 09:08 pm
spark plug wire change on 06 turbo limited manzanman General Turbo Discussions 6 11 Apr 2010 10:11 am
Another spark plug question :D CruseadorPT Tech & Performance Forum 3 10 Aug 2009 10:00 pm
Suggestion on Spark plug and wire? oLEFTo Tech & Performance Forum 13 08 Jul 2009 11:53 am
air filter,spark plug & wire brands/opinions bob67firebird428 Tech & Performance Forum 21 14 Jun 2008 04:05 pm
