fuel line question...
Old 14 Feb 2011, 11:12 am
Default fuel line question...
So I changed the plugs & wires on my 2006 turbo convertible and snapped off the fuel line where it clips into the main line at the fire wall. I bought one of those kits that you cut & splice in to the existing line, but I'm not comfortable with the patch job.
Two questions...
1. where can I find the replacement gas line that clips from the main line to the engine (searched and found nothing)
2. How does it detach/attach to the engine (looks like there is a white plastic tab) I know with the main line connect, you have to squeeze the plastic tab to release...
Thanks, learn a lot on this site!
Old 14 Feb 2011, 07:42 pm
UptownSport's Avatar
Default Re: fuel line question...
Ours broke, too.
I used a 2d gen Neon line, cut it off, heated it and pushed it on the barb.
Both ends come off the same way.
Neon's little accumulators seem to all weep.
I agree replacements seem flunky, I'd buy new regardless of cost- Just isn't
worth having a PT weenie roast on side of freeway
Old 15 Feb 2011, 08:10 am
I did the same thing buy instead of snapping it by the firewall I broke mine where it goes to the fuel rail. Is there a part number that I can use to just order that whole line from a dealer or what is the best way to fix that?
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
Old 15 Feb 2011, 08:25 am
The dealer can look it up for you. You don't need the part number before you go and as Uptown Sport already said, it's best to get a new line rather than piecemeal something together.
This is what happens when a fuel rail leaks onto a PT engine.
Old 15 Feb 2011, 08:39 am
well I wanted a part number so I could order it online. I found a dealership that has an online parts site that is half the price of my local dealer.
Old 15 Feb 2011, 09:12 am
OK, since yours is a 2001 (same as mine) I have the Chrysler PT Cruiser Parts Manual.
The line (I think your talking about is called: Tube, fuel supply (fuel line to rail front). No. 5278 260AA
Old 15 Feb 2011, 10:01 am
Thanks CREWZIN, I'll call the stealer... 2006 might be the same as the 01. How does it unclip from the front?
Old 05 Jan 2012, 01:49 am
hi i have a pt cruiser and i need the same part i was wondering if you would share the website with me i reall need to get my car running again.
Old 05 Jan 2012, 02:05 pm
Folks, our ma Chrome has collected a very helpful library, it's at the top of this forum:
PT CRUISER TECHNICAL DOCUMENTS LIBRARY
Download your specific year, look through for your engine / model and run that part number online.
And I think it's really, really important to look closely at what Crewzin posted.
Underhood fuel leaks are the worst thing that can happen to your drive.
Old 12 Oct 2014, 03:12 pm
Hi,kinda new here for posting. My question is like someone else asked can you do away with that clip and the accumulator, and just use clamps to hook it up directly? If not why not? Does the accumulator act like an expansion valve for the fuel pressure? It's sunday no dealers are open and working on car now. thanx in advance jim
turbo supply line question 4SPEED General Turbo Discussions 2 01 Feb 2011 12:51 pm
Belt line trim question. WolfmanG General PT Cruiser Discussions 15 23 Jan 2011 06:29 pm
air/fuel question 03greygtcruiser Turbo Performance 0 23 Feb 2008 07:07 pm
NEW 2007 Cruiser had a leak in fuel line stacigw General PT Cruiser Discussions 1 20 Nov 2007 09:52 pm
Fuel Pump and assembly line stirfry General PT Cruiser Discussions 1 09 Oct 2005 09:29 am
