transmission troubles
Old 14 Feb 2011, 11:26 am
tjc tjc is offline
Unhappy transmission troubles
Hi, I have a 2003 Pt turbo cruiser and my transmission is leaking. It seem s to be coming from the top. There is a vent there and people are telling me you cant fix that the whole trans has to be rebuilt??? Is this True?? I dont have any trouble shiting. It rides great.
Old 14 Feb 2011, 12:59 pm
cruserdad1976's Avatar
Default Re: transmission troubles
it is probaly thr selonide that sits on the top check the post there is one about changinf this
Old 14 Feb 2011, 01:38 pm
ROCKETMAN8060's Avatar
I did mine yesterday! Here are some pictures!
ROCKETMAN8060
Old 14 Feb 2011, 03:15 pm
tjc tjc is offline
Hey Rocketman, Thanks!!! Is it hard to get to this selonoid part? What do you take off?
Old 14 Feb 2011, 04:31 pm
What up bro! Well make sure if your going to do this job you know what your doing! If you let any dirt to go into the solenoid it can give you trouble for real! The car wont change gears and so on! Try to work really clean! I got 6 cans of break cleaner, I used 2 to clean the area around the Solenoid system to make sure no dirt was going to go inside the Trans before I removed the part! Im sorry I didnt took more pictures about this job but if you need help send me a email with your number and I call ya! You have to remove the battery, air box, the intercooler hose, the bracket that holds the battery, the plugs that goes into the solenoid and sensors, the 2 hoses that goes to the oil cooler and with that you will be good to access the 3 bolts that goes into the solenoid system that you can see in the picture I send you! If you do this right you can be done in just one day! Let me know what other info you need and I be more than happy to help ya!!!
ROCKETMAN8060
Old 14 Feb 2011, 04:38 pm
WOW that is a lot more detailed than I thought it would be a lot to remove
Old 14 Feb 2011, 04:55 pm
LOL!!! Thats why you really need to know what your doing when it comes down to Trans! The smallers mistake can cost you a new one!
ROCKETMAN8060
Old 14 Feb 2011, 05:51 pm
tjc tjc is offline
Thanks Rocketman.
Old 15 Feb 2011, 10:44 am
Agree with Rocket, the key to doing this job is to make sure you clean the area very well before removing the solenoid. Once you have removed the solenoid make sure you have zero dirt that can potentially fall into one of the many hydraulic passages. The job is not that difficult and can be accomplished with standard shop tools and on non turbo models should not take longer than about an 2 hours.
Old 15 Feb 2011, 11:58 am
Dino's Avatar
TJC
This is a very busy forum, I would get your cell off it, pm him the number.
Car Troubles PTCMIAH62 General PT Cruiser Discussions 9 07 Sep 2010 11:00 am
New guy... MBC troubles SRT Turbo Performance 3 02 Apr 2010 10:40 am
'05 Cooling fan troubles captcueball Tech & Performance Forum 3 03 Jun 2008 02:48 pm
Lowering Troubles TemporeLegis General PT Cruiser Discussions 1 18 Sep 2007 02:37 pm
Wheel troubles on GT robinjoe Wheels, Tires, Suspension 3 24 May 2005 07:03 pm
