idle stumble
Old 14 Feb 2011, 02:55 pm
themadgreek187's Avatar
Default idle stumble
yes i know they are countless threads on this. changed my plugs again yesterday. went from autolite iridium to the champion double plats 7570. changed the pcv valve as well. checked all hose lines and replaced the pcv hose. vacuum line is tight. still i get a small stumble at idle. if in park its not bad, but when my foot is on the brake at a stop it stumbles pretty bad. ran some sea foam through the gas tank to see if it clears it out. any other suggestions?
Old 14 Feb 2011, 03:41 pm
Default Re: idle stumble
Clean idle air controller (carbon build up)or replace if necessary. Clean throttle body. I did this and helped out alot.
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 14 Feb 2011, 03:57 pm
You didn't say anything about changing your plug wires.
Old 14 Feb 2011, 04:15 pm
yea this was my next step.
Old 14 Feb 2011, 04:16 pm
yes i did this a month ago when i did the plugs the first time.
Old 14 Feb 2011, 06:39 pm
Did you use something other than OEM????
Old 17 Feb 2011, 01:04 pm
yeah went with autolite premiums. i'm not a n00b at changing the plugs and wires and i do my research. my neighbor thinks it is a vacuum leak somewhere. inspected all hoses and all are good to go. next thing i will try is replacing the rubber gaskets on the upper and lower intake manifold. maybe they have worn out.
Old 17 Feb 2011, 01:13 pm
Spray starting fluid along intake manifold seams - if idle smooths out, it proves there's a bad intake gasket.
Really? A/C Compressor Stumble Is Normal? NewPTCruiserInPA Tech & Performance Forum 175 12 Sep 2020 12:56 pm
Hesitation\stumble off idle k9t8m Tech & Performance Forum 4 30 Jul 2009 07:06 pm
Stumble at 4k rpms in neutral 05CruisergtHO General Turbo Discussions 1 24 Apr 2008 03:26 pm
The 3rd gear stumble is gone! sakigt General Turbo Discussions 1 06 Jun 2004 12:33 pm
Low-rpm stumble with AC? jbrown1977 General Turbo Discussions 3 19 May 2004 01:14 pm
