Oil Pressure Sensor ,What tool is needed
Old 17 Feb 2011, 02:08 am
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Default Oil Pressure Sensor ,What tool is needed
Hey fellow Pt groupies. I have the 2006 PT Cruiser Touring non turbo automatic and it is having an issue with the oil pressure sensor. It needs to be removed and I would like to know if anyone has tacked this issue before and what tool is need to remove that nicely built sensor??
Also has anyone had problems with there dome light not coming on when you turn the switch alos it controls the dimmer for your interior lights for the gauges.. Mine will come on if I hit a bump and things like that.
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
Old 17 Feb 2011, 02:59 am
outfit's Avatar
Talking Re: Oil Pressure Sensor ,What tool is needed
23 Nov 2009, 10:17 am
DEEGO
DEEGO's Gallery
Oil Pressure Sending Unit
Hi all savvy PT'erz!
I had to replace our Oil pressure sending unit/switch this weekend because it was causing an oil leak. I just wanted to give everyone some tips.... It is very hard to try to reach the sensor from under the car. What we did was we removed the battery, air box, we also moved the fuse box aside just a bit to get more room to work (not necessary though). After removing/moving those parts we had plenty of room to work with. Simply disconnect the electric connection and remove the sensor with a socket. The part was $11.99 at Kragen with a lifetime warranty! (not just a dealer only item :]) The socket isnt a special socket its just a 27mm ($9.99) deepwell. I hope this helps someone, overall the job wasnt hard so no need to pay anyone to do it for you! :]
I found this post, 2009 yeah i did some searching.. going to be fun
Old 17 Feb 2011, 07:01 am
Wishbone's Avatar
Default Re: Oil Pressure Sensor ,What tool is needed
Had mine replaced under warranty last month. It was leaking pretty good.
Install - Oil Pressure Sensor geronimo Tech & Performance Forum 27 02 Feb 2015 04:31 pm
Oil pressure light problem - just replaced cam sensor jeremyrocksursox Tech & Performance Forum 5 02 Jul 2010 10:22 pm
releasing the oil pressure sensor geronimo General PT Cruiser Discussions 0 29 Mar 2010 03:31 pm
Part number for Power Steering Pressure Sensor runtime General PT Cruiser Discussions 1 13 Mar 2008 08:26 pm
power steering pressure sensor ravix Tech & Performance Forum 2 15 Apr 2007 09:46 am
