2002 Cruiser OBDII Problem
Old 17 Feb 2011, 06:28 pm
Default 2002 Cruiser OBDII Problem
I have a strange one. I took the Cruiser in for it's annual inspection and when it got to the part where the inspection machine requests date from OBDII it barfs and displays:
"The OBD Connection cannot be confirmed or data cannot be captured".
It did this on multiple attempts at two different inspection stations. I can hook up my scanner and look at stuff, I forced a code by pulling the cable to the MAP sensor, pulled the code with my scanner, reset the code, etc. but the inspection computer can't appear to communicate.
Anybody ever run up against something like this?
Thanks...
Justin B.
2002 Touring Edition
Old 17 Feb 2011, 09:41 pm
cruserdad1976's Avatar
Default Re: 2002 Cruiser OBDII Problem
there was a guy who had a broken pin and the obII could not get a reading
Old 18 Feb 2011, 05:26 am
Was he still able to use a scanner normally on the port! I can still watch sensors, pull and clear codes, etc...
Justin B.
Old 18 Feb 2011, 08:42 am
If I remember right, yes. It'd work at AutoZone, but not at inspection station.
I forget resolution - but it was a single pin, I believe.
Old 18 Feb 2011, 03:25 pm
It will in all likelyhood be a bent or broken pin. You'll now have to get on your back in the drivers side footwell with a magnifying glass and find it. Still, it's strange it would work with one and not the other.
Jerry
Old 18 Feb 2011, 08:32 pm
Thanks, I'll take a look under there next week. It would be great if it turned out to be something as simple as a pushed pin!
Justin B.
Old 26 Apr 2011, 09:59 pm
I finally got around to pulling out the datalink connector and sure enough there was a "pushed pin". Dang made in Mexico crap, anyway!!! I pushed home all of the pins and it passed the OBDII test with flying colors...
Thanks for the help.
Justin B.
Old 27 Apr 2011, 12:31 am
Glad to hear that you got it all working. I will have to check both .... I can't read my 01 or 06 with my Actron reader that works just fine on my other Made in Mexico car ..... the Beetle. I did not try my VW one on the PT. The one that Advance Auto Parts had a two different stores worked fine and was the same one that Autozone had also ..... but none of these stores sold that model anymore. I purchaced the best new Actron under $200 at one of these stores and it would not work either. I returned and bought a 1/2 price clearance one at Sears for $25 .... works great to read the 06, have not had to try the 01, but that one works with the keyflip and I can't get my 06 to do that either.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 27 Apr 2011, 09:49 am
Eh, don't go so hard on Mexico. The cars are assembled there. Design is the art of having the part only go in one way so it can't be mis-assembled. And I would bet many of the sub assemblies are made elsewhere, shipped to Mexico and then assembled.
Like many of you, I too have owned cars that have been "made in America" and had a few issues with them.
alan
Old 27 Apr 2011, 10:55 am
alan
I only own 1 vehicle not Made in America ..... Mexico is in the America's Right?
You are right though ... every time I look at a peice of engineering that had failed in some way .... I wonder what they were thinking. And I am not an engineer.
12 Regal Turbo
90 F150
73 Mach1
Stage1 and OBDII tests Fuct Stage Turbo Kits 2 09 Feb 2011 02:25 am
OBDII Error codes (help?) PoppaGrunt Tech & Performance Forum 9 24 Jan 2011 11:37 am
2002 CHRYSLER PT CRUISER **DREAM CRUISER** (hayward / castro valley) $9995 skylight craigslist 0 14 Jul 2007 04:30 pm
Idle problem on new 2002 pt sain1 Tech & Performance Forum 4 18 Apr 2002 11:29 am
Idle problem on new 2002 pt sain1 Tech & Performance Forum 0 01 Jan 1970 12:00 am
