Rough idle problem
  • 1 Post By veracruise
Old 19 Feb 2011, 02:20 pm
veracruise's Avatar
Default Rough idle problem
My PT cruiser has been running
rough and using alot of gas. I
did a timing belt change a couple
a months ago and has been running
rough ever since. It starts up like
it should with no problems, only
at idle it's rough. But as soon as
I take off to drive it runs normal
and runs smooth. I am also going
to check the coil to how good the
spark is. Also I noticed when i
took the intake off, I noticed excess
oil around the openings of intake
gaskets (what would cause this)?
Also I am going to check the
compression to if that would be
the cause of rough idle. Anybody
have any other suggestions?
Old 19 Feb 2011, 03:33 pm
Default Re: Rough idle problem
Timing could be 1 tooth off. Coil in our PTs are virtually indestructible, only 1 coil reported to be bad and that was just within the week. Good Luck, let us know what you find.
Old 19 Feb 2011, 03:46 pm
...and I'm still not sure it wasn't an aftermarket coil on that guys car since the original owner did all kinds of mods including an after market turbo conversion ....but that's another story.
Agree with Hooligan as the main thing that owners came here with rough idle after a timing belt change turned out to be the timing being off 1/2 or one full tooth. The timing belt job is not easy and those without experience changing it can easily make a mistake putting it back together and getting the marks correct.
As far as your excess oil in the intake. When was the last time the PCV valve was checked or changed.
Old 19 Feb 2011, 05:19 pm
veracruise's Avatar
The PVC hasn't been changed
Old 19 Feb 2011, 05:22 pm
veracruise's Avatar
The PVC hasn't been changed.
We had the timing marks lined up
the way their suppose to be.
Whould there be a chance that
belt sliped or something
Jollanza likes this.
Old 19 Feb 2011, 08:16 pm
I don't know the particulars of changing the belt but that's always a possibility (belt slipped) and there's a lot of talk from guys who have done it that everything looked like it was lined up and when the put the belt back on, it wasn't lined up when they finished. Apparently it can move once the belt is put on.
Old 19 Feb 2011, 09:38 pm
veracruise's Avatar
Yeah, we had to take the belt on
and off 3 or 4 times to get it right.
(we thought)
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
Rough idle PtTurbo04 General Turbo Discussions 5 13 Sep 2010 03:07 pm
Rough Idle badkarma76 Tech & Performance Forum 30 21 Jul 2009 07:47 pm
Rough idle 03 GT elmeyer Tech & Performance Forum 2 03 Jul 2009 09:44 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
