indicators and wipers
Old 22 Feb 2011, 08:05 am
Default indicators and wipers
My indicators and wipers stopped working all other things on the dashboard are OK. Could this be a fuse and if so which one. I have lost my PT manual and the dealership can't look at it until Thursday and estimates a 4 hour min to check it out?? help please
Old 22 Feb 2011, 08:10 am
meder2487's Avatar
Default Re: indicators and wipers
Sounds like your multifunction switch is going bad. It is pretty easy to remove from the car. You can use this link here to show you how to remove it:
Replace Multifunction Switch w/fog lamps
I would look around inside at the connections and make sure nothing is corroded, broke or disconnected. You can even price a new one at a local scrap yard. They should not cost that much and that is a much cheaper way then going to the dealer.
Don't Blink
Old 22 Feb 2011, 08:45 am
meder2487 is probably right but in case it is a fuse or relay, unless you give the particulars of your car I can't help. Too many changes in some years.
Old 28 Dec 2012, 03:36 pm
Hi,
I'm facing the same issue... bought a 2006 PT cruiser and its the 2nd time in 30 days this has happened. The wipers/indicators/headlights have stopped working. 1st time when this happened, the mechanic replaced the fuse box and it started working fine, now within 10 days again the same thing has happened. Wipers/indicators aren't functioning. Not sure what is causing it and how it can be fixed? Please suggest...
INDICATORS TURN SIGNALS HAZARDS PATGAS Tech & Performance Forum 9 29 Oct 2013 04:59 pm
Wipers come on by themselves?? flamingojohn Tech & Performance Forum 4 21 Aug 2010 03:56 pm
New Multifunction Switch but still no indicators/hazards. Please help! vard3n General PT Cruiser Discussions 4 28 Aug 2009 12:08 pm
wipers???? cruisergeo Exterior Accessories Forum 5 24 Aug 2003 08:04 pm
