Service Engine Soon Light
Old 25 Feb 2011, 10:35 am
Question Service Engine Soon Light
Hello everyone,
I am new to this forum and welcome any and all replies to this post.
My "check engine light soon" came on 3 days ago. I took it to AutoZone and had the diagnostics run. The first cause was a gas cap malfunction, so I replaced the gas cap.
I asked the service rep when the light would go off. He told me that it would in a couple of days, and if it didn't to come by in a week and he could advise me further.
Does this make any sense? It seems to me that if the gas cap was the problem, the "check engine light" would go off as soon as that gas cap was replaced.
Any thoughts on this?
Old 25 Feb 2011, 10:47 am
Default Re: Service Engine Soon Light
disconnect the negative battery cable for about 10 minutes. that should clear the code.
Old 25 Feb 2011, 12:19 pm
white's Avatar
And it takes a few starts to clear codes with out removing the battery cables.
E. White
2010 Black over Silver, Couture Edition
Old 25 Feb 2011, 12:53 pm
Welcome to the forum.
...and you probably didn't need a new gas cap. If you don't turn the cap at least 3 clicks after filling it with gas, the light will probably come on. If you tighten it again (3 clicks), the light will go off as white just said. Sometimes it takes a few day. Depends on how many times you start the car.
Of course AutoZone won't tell you all this. They diagnose the code and sell you a part.
Next time you get the light, come here first. We'll tell you how to read the code and hopefully tell you what's wrong and how to fix it.
Old 25 Feb 2011, 04:25 pm
Smile Re: Service Engine Soon Light
Thank you very much for your help.
Old 25 Feb 2011, 04:49 pm
cruserdad1976's Avatar
kinda odd that they did not clear the code for you???? oh well im not a autozone fan anywya
Old 25 Feb 2011, 04:53 pm
cruserdad, it may be a store policy I noticed they dont do it unless you specfically ask them to clear the codes. Even then they ask for confirmation that you want them to, they may have had some complaints over unintended code clearly at some point.
Old 25 Feb 2011, 04:57 pm
I had a little better luck at Autozone they did not reset the code, but also did not sell me a gas cap. The nice lady said to make sure it clicks a few times and wait. It also took over a week for it to go out. I had left my cap off for a hundred mile trip with a couple of stops. I did the same thing a year later and again the light took almost 2 weeks to go off. but I don't driver very often, but when I do it is for long trips. I left it off for another long trip but caught it when I stopped with no stops in between and the light did not come on. So it appears that the cap must be loose, or off, for multiple trips for the code to be set.
Old 25 Feb 2011, 04:59 pm
could be I knwo the dealers like it when the codes are still in the computor when they have to work on them
Old 25 Feb 2011, 08:45 pm
WolfmanG's Avatar
Welcome to the forum. Greetings from San Antonio from Eve and I.
I agree with Crewzin. come here first before anything else.
-Danny Wolfman G
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Engine light ejstith General PT Cruiser Discussions 25 18 Sep 2010 12:46 pm
Engine light on PTC06Peet General PT Cruiser Discussions 7 22 Dec 2008 01:26 pm
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
Engine Light On PT-Dave Turbo Performance 3 29 Jun 2003 06:04 pm
