whistle
Old 26 Feb 2011, 01:04 am
urimashe's Avatar
Default whistle
hey guys, i noticed this when i got the pt, when i start going from a dead stop and speed up, shifting the gears when i need to, i somtimes here a whistle from the passenger side of the dash, the sound is comming from the dash. i know this becouse i dont hear it outside when i stick my head out the window. anyone know?
2006 Base PT Manual Tranny, K&N drop in filter, Marine Blue paint, Name: Blue Monster, Body style: Path Cruizer... oh yea, seat covers? got em.
Old 26 Feb 2011, 02:55 am
Default Re: whistle
No idea, but try flipping the dial that either takes in outside air or reuses inside air on the heater controls, since noise comes from dash.
Old 26 Feb 2011, 07:32 am
Default Re: whistle
I had a whistle noise when I had the original antenna. At certain speeds the high pitched noise would bother the heck out of me. Going to a shorty antenna cured that. As QSD said, change the positions of the HAVC knobs and see if that stops any of the noise. Another member has a "sucking sound" from the dash and changing the knobs helped a little but didn't take it all away.
Old 27 Feb 2011, 04:17 am
urimashe's Avatar
Default Re: whistle
tried the knobs, its still there, has somthing to do with the reving of my engine when im releasing the clutch. but i do know the noise is just in the dash, my sisters ford focus did the same thing, hers was a manual aswell. its not a bad noise, i just wana know whats making it.
Old 27 Feb 2011, 12:45 pm
CreepyPT's Avatar
Send a message via Yahoo to CreepyPT
Default Re: whistle
Air going through the air box sometimes sounds like it's coming from the dash. If you don't have a a performance or high flow air filter, you might check your air box to make sure it's closed tight, and then make sure your air filter is clean and doesn't have any small holes in it.
I had a dirty filter in my old buick, and the sound of the air trying to go through the small clean area at one end of it's air box made all kinds of odd noises till I changed the filter out.
Another suggestion: I took my side mirrors off to gauge what all I would have to take apart to paint them. While the were off I noticed one of the seals behind the passenger one was a little warped. I used a hiar dryer to heat it up and stretch it out straight, and that eliminated some of the air noise I was getting around the side mirrors at speed.
In any case, good luck with your noise. I tend to get pretty irritated at mystery noises myself.
Whistle Noise! 03 GT PT dewwy General Turbo Discussions 14 11 Aug 2010 11:07 pm
engine whistle 4SPEED Tech & Performance Forum 1 17 Jul 2007 09:22 pm
power steering whistle ptTurbo528 Tech & Performance Forum 5 25 May 2006 05:33 pm
High pitched whistle at WOT rice_killing_GT Turbo Performance 9 28 Nov 2003 08:39 pm
The Whistle... PeTe Turbo Performance 9 10 May 2003 12:25 pm
