Sunroof not working.
Old 26 Feb 2011, 10:19 pm
Default Sunroof not working.
Hi everyone,
I have a 2002 cruiser and the sunroof stopped working. No noise, nothing. If it does have a blown fuse, where would it be? Could it be the fuse, or something else. Pushing the bottons doesn't do anything, no noise or nothing. One other problem, my fog lights stopped working also. I have the green indicator that comes on in the instrument cluster but no lights. I have read it could be the multi funcution switch.
Thank you ahead of time.
George
Old 26 Feb 2011, 10:26 pm
Default Re: Sunroof not working.
George, welcome to the forum.
Do you know you have a fuse panel by your left knee while sitting in the driver seat? If you pull off the panel cover and read what the fuses are for on the back of that panel, you'll see that the No#14 fuse is for the sunroof and the No #8 fuse is for the fog lights.
If it's not the No#8 fuse for the fog lamps, yes it could be the multi-function switch on the steering column. A very common fault.
Old 26 Feb 2011, 10:47 pm
Ok well thank you so much. I have pulled the fuse box cover off many times, but didnt pay attention. Thank you very much, I will let you know what happens.
Old 03 Mar 2011, 10:03 pm
Sorry for the long time to post. I checked the fuses and there isn't any blown. My other question would be could the overhead counsol switch be bad, or a wire/ wire's be disconnected? Like I said before, when I push the switches (sunroof) nothing happens, not even a sound. And as far as the fog lights, the indicator in my dash still lights up green but no fog lights. After reading other posts I do belive I might have a faulty multi function switch.
Oh and I love my 2002 PT!! Thanks for the forum also.
George
Old 04 Mar 2011, 02:39 am
Kawizx9r's Avatar
If your green indicator light comes on when you flick on your foglamp, I would suspect that your bulbs might be out? I'd take a multimeter and measure voltage coming out to the lamp.
Reason I say this is because my multifunction switch is out as well, but when I turn on my foglamps my indicator light does not come on.
Could be wrong but just a thought.
Kawi is a friggin genius!
Old 04 Mar 2011, 10:20 pm
Thank you once again.
I'm going to check my lights and maybe they are blown out. I will have to do it either Sunday or Monday when I'm off. Any ideas where I could start as far as my sunroof goes?
Thank you all to a wonderful forum.
George
Old 07 Mar 2011, 10:38 pm
Hi everyone,
Well I found out the problems with my fog lights and sunroof. They weren't hooked up. My fog lights are working now and well my sunroof is also working BUT! It will open on vent, but when I go to open the sunroof it opens about a 1/4 inch then stops. It seems like it is being blocked, or stuck. Any ideas?
Thank you
George
sunroof help neon95 General PT Cruiser Discussions 2 19 Mar 2009 01:12 pm
sunroof neon95 General PT Cruiser Discussions 0 16 Dec 2008 08:50 pm
Sunroof blondecowgirl Interior Accessories Forum 3 21 Jun 2007 02:14 pm
sunroof HELP!!!!!!!!!! Lana Interior Accessories Forum 4 25 Sep 2006 04:38 pm
Air Dam for Sunroof hugh_mack General PT Cruiser Discussions 1 22 Nov 2002 08:38 pm
