Required Belt Change
Old 27 Feb 2011, 10:15 am
mjb457's Avatar
Default Required Belt Change
Ok I am at 89000 miles on my 2003 PT Touring(bought new) the owner's manual says 105000 for Timing Belt? the PT is not abused so is it safe to go to that time frame which will be next winter ( Ill budget the $$ ) I know Its been posted before but all suggestions are taken ..again thanks MJB
Old 27 Feb 2011, 11:11 am
meder2487's Avatar
Default Re: Required Belt Change
You may make it to 105000, but there is no gurantee. If it fails before next winter, you will be stranded wherever it fails and most likely you will have to be towed. That in itself adds a good bit of cash to the already pricey repair.
Don't Blink
Old 27 Feb 2011, 11:20 am
mjb457's Avatar
Ok when is recommended time?thanks MJB
Old 27 Feb 2011, 11:23 am
meder2487's Avatar
From reading on here, the PT is very consistant with having the timing belt go at or very close to 100000 miles. Some get more than that and some get less. I had mine done at 87000 when it was in the shop for something else, just to get it out of the way.
If the car is driven easily and has always been driven this way. You may be able to make it to 100000 or a little past. Ultimately it comes down to when one can afford to have the work done.
Don't Blink
Old 27 Feb 2011, 11:38 am
UptownSport's Avatar
Belt doesn't care whether rest of vehicle's been abused or not.
It does the same thing whether cruising at part throttle or under max load-
I do suppose there's someone who's used their PT to ford their goats across
a stream everyday, so no absolutes
Old 27 Feb 2011, 12:29 pm
tryingbe's Avatar
If you're planning to keep the car, I'd change it sooner rather than later.
85 GLH
Watch out for anchor engine mounts!!
Old 28 Feb 2011, 02:26 am
mdfrodolives's Avatar
I own a 2003 Limited Edition PT and the Owner's Manual says to replace the timing belt at 90,000 miles--not 105,000. That's a 15,000 mile difference. If it was a Honda, you could go 40,000 miles past the required mileage and maybe not worry too much. But PT's (from what I've read on here) are not so forgiving. I'm going to do mine at 95,000. That's halfway between what my manual says and what many posters say in this forum.
Tim
Old 28 Feb 2011, 02:34 am
Just read the '01 today- 120K miles!
I'd stick with 100K or sooner though
Old 28 Feb 2011, 04:30 am
swanjack's Avatar
Mine's just been changed at the same time as a head gasket fix. 82k miles. I had a look at the old belt and you could see the outline of the teeth from the back of the belt. The company that I get parts from recommends relacement at 90k miles, which judging from the wear on the belt seems about right.
Old 28 Feb 2011, 09:02 am
mjb457's Avatar
,,total price paid? including all parts with water pump? & time they stated Mjb
When to change a timing belt miralu Tech & Performance Forum 3 01 Feb 2011 06:11 pm
Timing Belt Change? tgibeau Tech & Performance Forum 10 07 Jun 2010 10:21 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
Timing belt change turbomangt General Turbo Discussions 31 19 Jan 2009 04:48 pm
Tools required for brake change? scrisp2 General PT Cruiser Discussions 5 06 Sep 2006 09:11 pm
