Argh! Check engine light!
Old 28 Feb 2011, 08:03 pm
Unhappy Argh! Check engine light!
*sigh*
Started my '07 Cruiser today, jumped out and cleared the snow off of her. There was a weird kinda burning smell so I looked under the hood. Don't see anything wrong. No odd noises. I figure that it's one of the other cars around me. Smells like a dragging e-brake. I jumped in... no oddball lights on the dash, running fine. So I head out...
20 minutes later I stop at the store. All is still fine. Get back in the car and start it up. Everything is still fine, except now the check engine light is on. I shut the car down and try to pull some codes. All I get is "-done-". Car is running fine, no smells, fluids are all at their normal levels and all the belts are moving, so I drove home.
At this point the light is still on and I don't see any issues. Chrysler dealer is at least an hour away.
...anyhow, does anyone have any idea where to start with this?
[edit] I should mention that the temps here are -23'C, -37'C with windchill (-9'F and -34'F) but I've never had problems in the cold before.
Old 28 Feb 2011, 08:17 pm
Kawizx9r's Avatar
Default Re: Argh! Check engine light!
No leaks?
Disconnect the negative terminal on your battery for a bit then plug it back in to reset your engine light. If your light comes on again, hopefully you'll get a code telling you what the problem is (if any).
Kawi is a friggin genius!
Old 28 Feb 2011, 09:06 pm
WolfmanG's Avatar
i had the same prob. you might want to go thru this thread and see what others said about the prob
also, from the time you left your house to the time you came out of the store, did you put gas?
Eve say's shes sick but she wont tell me what's wrong.
-Danny Wolfman G
Old 01 Mar 2011, 12:46 pm
Nope... no gas. Just drove from my work parking lot to the pet store for gecko food... Maybe my car is just afraid of crickets!
Now that the car is cold I'll poke around a bit more under the hood. It wouldn't be so bad if it wasn't -29'C right now - I've got no garage.
I'm just glad I hadn't started messing around with my ground straps or installing my radio yet or I'd really be barking up the wrong tree.
Old 01 Mar 2011, 01:00 pm
I should have mentioned in my first post... This is an automatic, base model with 45,000km (28,000miles) on it.
Old 06 Mar 2011, 01:19 am
Thumbs up Re: Argh! Check engine light!
...so, a thorough check did not find any issues, so I disconnected the battery for a while. Hooked it all back up and no more check engine light. Drover her around the last few days and no problems.
At this point I don't know what happened, and I'm glad that it seems to have resolved itself.
Thanks guys!
Old 07 Mar 2011, 11:51 am
Unhappy Re: Argh! Check engine light!
I knew it was too good to be true.
Got the check engine light back today. At least I got some codes this time...
P0481 - Cooling fan #2 circuit.
P0522 - Oil pressure sender. The sender is messed up. First time I got a code for it though.
I *hope* it's not going to be a pain to fix this... *sigh*
Old 09 Mar 2011, 11:30 am
Default Another update...
50 amp radiator fan fuse is blown... That would account for the error code.
Now, to get another fuse and hope it doesn't blow.
Old 20 Mar 2011, 04:16 am
Smile Followup
I replaced the 50 amp fuse and it hasn't blown again, BUT I finally figured out that I had a bad radiator fan. When it came on, it would draw a LOT of power and eventually blew the fuse. Well, the fan finally it died and would only throw sparks and smoke.
I've replaced the fan with a unit from AutoPartsWay here in Canada and everything seems fine now.
One item I do have to mention about the replacement... It had no holes to mount the wiring harness that leads from the plug to the relays. It was easy enough to add them with a 1/4" drill bit, but definitely not expected.
Tags
burning, engine light, smell
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check Engine Light on bucksfan1976 General PT Cruiser Discussions 9 04 Aug 2010 09:47 pm
Check engine light is still on! cowboyinboxers Tech & Performance Forum 2 01 Jun 2010 06:44 pm
Check engine light just came on! lajag24t Tech & Performance Forum 22 13 Aug 2009 05:22 pm
check engine light ccprez Testing 12 16 Mar 2008 08:22 am
