Engine surged & cut off at 50 MPH
Old 03 Mar 2011, 11:38 am
Unhappy Engine surged & cut off at 50 MPH
My wife bought me a 2005 PT Cruiser from a used car dealership for Xmas. I had all fluids changed, tune up, new motor mounts, rack & pinion, control arms, battery & some nice chrome wheels. Last night while traveling at 50 MPH, the engine revved up as if it was down shifted to a lower gear and it shut down. All electronic functions and lights still worked OK but it would not re-start. A quick call to the dealer suggested that the car's ignition stopped recognizing the ignition key & to try my alternate key. Well, the other key got the same results. I finally had to have her towed to the dealer for a diagnosis and hopefully a fix. Has anyone experienced this?? SCARY!!
Old 03 Mar 2011, 12:04 pm
cruserdad1976's Avatar
Default Re: Engine surged & cut off at 50 MPH
does it still cran over???
is it that it just will not start???
or is there NOTHING when you turn the key
Old 03 Mar 2011, 01:42 pm
Hello & thanks for the quick reply. I just heard from the dealer...evidently there is a fused network that includes the starter. Two of the wireds in that area had frayed away exposing the bare wires that somehow touched each other when I got up to high speed. The harness is OK. I will know and report more tomorrow...
Old 03 Mar 2011, 01:46 pm
Oooops...sorry cruserdad1976...I forgot to answer your question...No, it would not crank and there was nothing when you turned the key. All lights worked, radio worked, signals were fine, and all dashboard lights and monitors worked fine.
Old 03 Mar 2011, 02:46 pm
Welcome to the Forum. Sometimes it is important to include the mileage when you ask a question.
Old 10 Apr 2012, 02:04 am
My 2005 has done the same thing. How was your problem resolved?
Old 10 Apr 2012, 06:42 am
He told you in post #3 ....bad wiring.
Old 10 Apr 2012, 09:06 am
Thanks. My car is in the shop now and they are telling me they are changing the ASD Relay and that I probably need a new starter........but, I've never had a problem with the starter. I gave them permission to replace the starter, but now I'm second guessing them. I'm not feeling good about this after reading so many other comments about similar problem. Thanks again. We'll see how this turns out :-(
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Pt Crusier engine change with a neon engine? reepos1 Tech & Performance Forum 2 09 Nov 2010 11:21 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
Engine lurcing + engine lite come up on 05 GT Roadmaster General Turbo Discussions 11 18 Apr 2009 01:10 am
N/A Base Engine vs Turbo Engine Kirby General Turbo Discussions 7 02 Oct 2003 01:42 am
