R&R Glovebox Lock Cylinder
Old 04 Mar 2011, 07:18 am
Default R&R Glovebox Lock Cylinder
Does anyone know how to pop the lock cylinder out of one glovebox latch and install in another?
Thanks!
Vjk
Old 04 Mar 2011, 10:24 am
Default Re: R&R Glovebox Lock Cylinder
On mine, there's 4 phillips head screws in back of the lock and latch. Did you try taking them out and see if the lock is accessible ?
Old 04 Mar 2011, 11:22 am
Yes. I can't get the cylinder to come out of the sleeve. I was hoping someone know where to press or pry without going gorilla on it
Old 04 Mar 2011, 02:09 pm
on the few that i have done, whether it be door lock or car lock, the key has to be in the cylinder to remove. just a thought.
Old 04 Mar 2011, 11:19 pm
From the 2003 workshop manual; Unfortunately I can't supply the illustrations.
Remove glove box.
"Open front passenger door.
Open glove box door, push in on box/bin sides
to release the glove box
Allow the glove box to drop down. With a firm
quick motion, twist the glove box assembly off the
hinge pins."
Disassemble glove box.
"With glove box assembly on bench, remove
eleven glove box assembly screws"
Remove handle lock assembly
"Insert key into glove box lock cylinder. Using a
small pocket screwdriver or equivalent, push in on
retaining tab (on side facing handle) as you turn the lock cylinder 90 and
pull out lock cylinder"
Reassemble lock and glove box
" Insert key into lock cylinder.
Push lock cylinder into latch and turn to
straight up and down position. Remove key.
Reassemble glove box assembly and reinstall
into vehicle."
Thanks!
Vjk
Old 02 Jun 2013, 09:31 pm
Apologies for dredging up an old thread, but I'd like to just post that the above steps work for the 06 glove box too.
Old 19 Aug 2014, 03:21 pm
I have an 06 cruiser convertible and the glove compartment latch is broke how do i get it out to replace it.. I dont know how to use this forum so i dont know when you reply how to find it again.. help please!
Old 19 Aug 2014, 04:48 pm
You found this thread and now only need to read the other answers in this thread to have your instructions.
Link/Rod: Front LH Door Lock Cylinder to Latch gashog Classifieds: Want To Buy 0 13 Oct 2010 06:43 pm
Replacing Ignition Lock Cylinder--Done Matt42 Tech & Performance Forum 2 20 May 2010 10:10 pm
Glovebox Switch ? 2step PT Cruiser Convertible Forum 0 02 May 2005 06:19 pm
holes in glovebox onyx pt General Turbo Discussions 0 31 Aug 2004 06:00 pm
Glovebox Light OldKen Interior Accessories Forum 5 14 Nov 2003 08:49 am
